hi guru,
i received the logarithmic pot that i mentioned before. It still results to the same poor result. which is something like below:
max resistance for the 10k POT is 9.79k ohm
resistance between input and C1 = 9.79k ohm very low sound
resistance between input and C1= 9.72k ohm the best volume
resistance between input and C1= 9.82k ohm suddenly very loud
i tried to observe the waveform at the C1 negative leg, the sine wave rise slowly with a very low Vp-p which is around a few milivolts.
Could it be something wrong with the boostrapped part?
thank you.
thank you.
