10 watt output quasi design
Discussion in 'The Projects Forum' started by simpsonss, Mar 16, 2010.
  1. simpsonss
    Thread Starter Active Member
    Jul 8, 2008
    173
    hi,
    this would be the quasi-complementary amplifier that i try to build it and observe it how it works.
    http://www.sentex.ca/~mec1995/tutorial/xtor/xtor6/xtor6.html
    When constructing the circuit there are a few doubts.
    What rate of transformer that i should use for my power supply part which is not mention in the tutorial. Any idea everyone?
    And what is the watt rating that i should choose for all the resistors? Could 1 watt be a good choice?
    thanks.
  2. R!f@@
    Apr 2, 2009
    8,792
    771
    R4, R5 around 2W
    R6, R7 around 5W cement.... do not use wire wound type
    R8 2W
    others low wattage
    as for power... u can suffice with 1 amps. but do check the voltage for sagging.
  3. JDT
    Feb 12, 2009
    658
    85
    A few tips:-
    To get your 30V power supply, use a transformer with a 24VAC secondary and connect a bridge rectiifier and smoothing capacitor. Transformer and rectifier at least good for 1A or a bit more. Capacitor about 4700uF, 35V to 50V DC.
    Before you first power it up, make sure that R10 is adjusted so that the base of Q1 is connected to the collector.
    I would advise temporally connecting a wire-wound resistor of say, 470 ohms in series with the power supply when you first switch on. This will limit the current and save your transistors if there is a fault.
    The positive end of C4 should be at about half supply voltage. Adjust R10 until you get a small continuous current through the output transistors (about 50mA).
    When you are sure that everything is OK, then short out the 470 ohm resistor and try it with some audio.
  4. R!f@@
    Apr 2, 2009
    8,792
    771
    I hear ya.... but I still say he will blow the output before he can hear anything :D
  5. simpsonss
    Jul 8, 2008
    173
    hi,
    thanks for all the replies. I would use a transformer with 24VA and 22Vac at the secondary voltage to get my 30V power supply.
    After calculating the watt for resistors R1 and R2 i will choose a 1/4 watt resistor for them.
    But what about the R3? how to calculate the watt across R3? Is it ~1.76mW?
    thanks.
  6. R!f@@
    Apr 2, 2009
    8,792
    771
    R3 is 470KΩ 0.25W will be OK
  7. simpsonss
    Jul 8, 2008
    173
    how do u actually calculate the watt across R3?
    thanks.
  8. R!f@@
    Apr 2, 2009
    8,792
    771
    experience
  9. retched
    Dec 5, 2009
    5,201
    313
    Ohms Law will help.
  10. simpsonss
    Jul 8, 2008
    173
    since the speaker i use is a 8ohm speaker. Can i connect the output to a 8ohm resistor to try before i connect the real speaker on to avoid any damage to my speaker?
    thanks.
  11. R!f@@
    Apr 2, 2009
    8,792
    771
    You want damage any thing if you do exactly what post 3 says.
  12. simpsonss
    Jul 8, 2008
    173
    u mean which part? the 470ohm resistor after power supply that part?
    thanks.
  13. R!f@@
    Apr 2, 2009
    8,792
    771
    exactly that
  14. simpsonss
    Jul 8, 2008
    173
  15. Audioguru
    Dec 20, 2007
    9,411
    896
    If the volume control R9 is wired correctly then it should adjust the volume smoothly from zero to maximum.
  16. dmccormick84
    Mar 3, 2010
    11
    Yes... I would use an 8ohm 20 watt resistor at a minimum. Many surplus outlets have hi-powered resistors at decent prices.
    dmccormick84
  17. R!f@@
    Apr 2, 2009
    8,792
    771
    R9 is the volume and any 0.5W pot would suffice.
    R10 is a trip pot which is used to adjust the biasing of the drivers and power stage.
    The noise could be that your bias is too low which is heard as distortion
  18. simpsonss
    Jul 8, 2008
    173
    hi,
    i change the R9 potentiometer from 4k7 to 5K7. then i manage to tune the volume lower.but still when i tune the volume to the lowest point the volume still too loud for me. Is it because of the bias part?
    thanks.
  19. R!f@@
    Apr 2, 2009
    8,792
    771
    Are u hearing any thing from the speaker
  20. simpsonss
    Jul 8, 2008
    173
    yes.i input the audio sound from a DVD player to the input point.But it seems like the volume is too high even i tune the volume POT to the lowest.
    thanks.
