You must have a very long slide rule. Mine is only good to 3 decimal places (perhaps 4 if I squint).Actually to correctly make the conversion from MFD to uF you need to use a slide rule and multiply by the appropriate constant. That constant being 1.0000000.
Speaking from experience?The speaker with the 10 MFD capacitor might be only 6 years old but the engineer who spec'd the 10 MFD condenser is probably 60 years old and studied electronics using MFD condensers.
by Aaron Carman
by Duane Benson
by Aaron Carman
by Jeff Child
