10 LED Sequencer -- Please Help!!! --
Discussion in 'The Projects Forum' started by pavel_1, Oct 21, 2008.
  1. pavel_1
    Oct 21, 2008
    I am trying to modify this 10 LED sequencer circuit (link below) in a way that it will turn on each LED in sequence and keep them ON and when it turns on the last 10th LED, just leave them all on. Sort of progressive light switch effect.
    http://www.allaboutcircuits.com/vol_6/chpt_7/6.html
    If you have any ideas, I appreciate it.
    Thanks,
    Paul
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  3. pavel_1
    Oct 21, 2008
    Thanks SgtWookie, although I haven't worked with LM3914. Do you have any suggestions on what kind of input signal I would need to get the result that I am looking for?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You would need a ramp, basically a triangle or sawtooth wave.
    You could make a ramp by using a constant current circuit to charge a capacitor.
