OK,
I need a solution as quickly as possible, of course I'm always considerate of those that lend a hand, so take your time! ;-)
I was going to use a NO relay that would be energized for two seconds to close the "1 touch dialing" keypad key of an old cell phone thus making a call, until I realized that their "1 touch dialing" requires you to touch two keys. (go figure!)
I thought I might get away with closing both keys at the same time, but the second key press requires approximately a 1 sec delay after the first. I have another relay available that energizes exactly the same as the first, that I could use to close the second key, but It would have to have a 1 sec delay, and I can't modify that boards circuit or I'll void it's warranty.
Of course I'd rather only use one of those two relays (power consumption on that board) to close both keys, so I thought I might build a small, simple circuit on a separate perf board, that I'll wire wrap and solder, that could quickly switch the second key within that 2 second window.
My supply voltage for this circuit is 12v DC. I'm looking for the simplest power conserving solution. One without a relay would probably be better from a power conservation standpoint.
Help! I really don't know where to begin.
My background:
In 1992 for just under a year I was an Audio Amplifier repair technician (and I use the phrase loosely). For the most part all I did was find fried transistors, resistors, capacitors, amp chips and cracked solder connections but wasn't very good at it. However my soldering techniques are superb ;-) I have a really nice fine point soldering station (though not a Weller it's a Tenma and a decent Radio Shack (Micronta) DMM, sorry no Fluke here. ;-) Oh, and I can read schematics pretty well.
So that's what you have to work with ;-)
Any takers?
TIA
My background:
Any takers?
TIA
