1 Sec buzzer pulse
Hrenowsky
Joined Aug 14, 2011
Hi!
I've got a problem, that i really would need some help.
I have a freescale programmer, which i am using at work.
As the programmer is almost entirely automated, i would like to add a sound indication when a pcb has been programmed ( so that other people using it, will know when they can replace the pcb and insert a new one).
The only problem is, that the programmer, when it's done with the programming cycle, turns on a led (success) and keeps it lit until the Start button is pushed and programming starts again.
I would like to add a circuit to it, that when the led is lit, would trigger a piezo buzzer for about half a second ( like a pc start beep) then turn off.
The circuit would have to reset itself when the led of the programmer turns off.
If it's any help, the programmer in question is a PE Micro Cyclone Pro.
