How much current does the other device need? Your power supply needs to be able to source current greater than the SUM of the current required by the. Two devices.
For example, say the first device requires 500mA. Then, the supply must be rated for greater than 2A. That is 1.5 A plus 0.5A (500mA).
No tech words, the current of power supply as the money in your pocket, the drawing current of device as the cost of stuffs that you want to buy, do you have the idea now?
