First posting to this forum, thanks in advance. Retired EE, but more of a MatSci guy than a circuits guy, as you'll see by my question.
The application is a sensor in the Bosch D-Jetronic (circa. 1970) electronic fuel injection system. The sensor in question is the cylinder head temperature (CHT) sensor, which is a thermistor with a resistance of about 2K ohms with the engine cold, and about 50 ohms with the engine fully warmed up. Sensor is single wire back to ECU with the other side grounded. High resistance = richer mixture, low resistance = leaner mixture.
We would like to have a circuit that uses a single pot positioned at the middle which would have no effect on the resistance of the CHT sensor as seen by the ECU. Turning the pot to the right would richen the mixture (i.e. add series resistance to the CHT), turning the pot to the left would lean out the mixture (i.e. add parallel resistance to ground to the CHT).
I can do this with switches or adding active components, but can't figure a passive circuit topology to do this with a single pot, which would be more desirable. Is it possible? I'm sure if it is, when I see it, I'll say.... "duh". Thanks in advance.
