1 Need Some Help
Discussion in 'General Electronics Chat' started by electro-man, Apr 9, 2006.
  1. electro-man
    Apr 9, 2006
    Hi guys, need some help choosing a resistor. I have a 12v 7.5aAh SLA battery and would like to alter the voltage to around 4 volts or so I'd like to use a resistor - what amp rating (ie: 1/4 watt, 1 watt etc.) and resistance.
    Cheers.
  2. n9xv
    Jan 18, 2005
    329
    It depends on load current. The series droping resistor is connected in series between the battery and the load. The calculation is;
    (Battery voltage - 4) / load current
    4 is the desired voltage in your case.
    With a resistive voltage divider like this, the voltage may not be stable depending on load current demands. Depends on what your trying to do with the 4-volts.
  3. paultwang
    Mar 8, 2006
    80
    What is the voltage tolerance of your load before you begin to damage it?
  4. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    You'ld be much better off with a voltage regulator, but again, need to know what sorta current your after...??
