1 million hours ?
Discussion in 'General Electronics Chat' started by iulian28ti, Jan 30, 2010.
  1. iulian28ti
    Dec 4, 2009
    42
    http://www.cde.com/catalogs/947C.pdf
    PAGE 3 graph
    I know it's Cornell-Dubillier, and i know lower voltage prolongs capacitor life, but anyone can exaggerate. What do you think, do they exaggerate ? :confused:
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Look at it this way - it's going to take over 114 years to find out.
  3. THE_RB
    Feb 11, 2008
    5,435
    1,305
    And let me guess it has a 12 month warrantee? :D
  4. iulian28ti
    Dec 4, 2009
    42
    That would be funny :p
  5. someonesdad
    Jul 7, 2009
    1,585
    141
    If it's important to you, call them and find out. Reliability prediction like this is often based on accelerated testing at higher temperatures which is then extrapolated down to lower temperatures using an Arrhenius relationship. Personally, I would evaluate the veracity by talking to the folks who did the testing, seeing the data and failure distributions, and learning about the physics of the failure mode(s). Unless you're going to be a big customer, they almost certainly won't share these data.
  6. t06afre
    May 11, 2009
    5,939
    1,222
    1 million hours ?
    Over my dead body, I would say
  7. Paulo540
    Member
    Nov 23, 2009
    188
    Just be sure to pass it down through the family. That way. if your great-grandkid uses it to build a time machine they could come back and tell you now.
  8. VoodooMojo
    Nov 28, 2009
    503
    53
    loosewire will be proud of you!
    this could be one of his "off topic" threads:rolleyes:
    i say this with deep respect for loosewire!
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Grossly over spec'ing the components only works if the power line never gets hit by lightning. It never hurts to have double the voltage rating, but more than that is iffy as to confidently extending component lifetime.
    At one time, using silver mica capacitors (don't think they are sold any longer) at much less than their voltage rating led to early failure.
    Some manufacturers are pretty good about publishing component lifetime studies.
  10. iulian28ti
    Dec 4, 2009
    42
    Well.... actually i wanna buy 1 million dollar worth of trimpots.
    Who would have thought electronics is full of humor :)
  11. 3ldon
    Jan 9, 2010
    82
    Depends what type of capacitor, water based units will corrode and evaporate.
    metalized polypropylene could conceivably last 100 years, my 1983 kenmore microwave that has been plugged in for 27 years now can attest to that fact.
  12. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I've got some really nice 1960's milspec tantalum caps that were pulled from obsoleted military equipment, they are 50 years old and still working perfect and I use them sometimes. But then they are quality too, non-corrosive metal outer shell, epoxy filled and low corrode nickel steel legs that still look good considering they sat about in a junkyard for probably 10 years in the weather before I get them.
    Ahh for the good old days when they cared about the quality of a component.
