1 channel, 1 LED color Organ
Discussion in 'General Electronics Chat' started by Aurbo, May 28, 2005.
  1. Aurbo
    May 6, 2005
    9
    Greetings
    I found the attached circuit diagram late last night and I have a few questions I hope someone might be able to answer.
    I know lower half of the circuit works, the audio transformer - 4.7K pot to single LED circuit works, but the circuit is no where strong enough to fire up a super bright LED or multiple leds..
    What I would like to know is if I could replace the 3-12v lamps to 3-5v LED's and the 25VAC transformer to a 12VDC power supply, What would you change the SCR value to ?
    My first thought was a L7805 voltage regulator but I think I am starting to mix apples and oranges.
    I wont have access to test or try this circuit for alt least 2 weeks, but I hope one of you guru's here might guide me in the right direction.
    I'm NOT an expert in this in any way, but I do like to tinker.
    Any help would be greatly appreciated.
    Cheers
    Aurbo
