Thank you very much.Hello,
Do you want to detect light or darkness?
This page of the EDUCYPEDIA has several circuits:
http://educypedia.karadimov.info/electronics/circuitssensorslight.htm
Bertus
Thank you.Here is your circuit:
Please tell me how the LED lights in those circuits?Thank you.
The circuits in the following works fine.
http://www.sentex.ca/~mec1995/circ/actrelay.htm
what do mean by 'how the LED lights in those circuits' ?Please tell me how the LED lights in those circuits?
Ron
Did you see the anything wrong with LED?what do mean by 'how the LED lights in those circuits' ?
yes, The LED should be connected in the opposite direction. I simulated the circuit by doing so and it works fine.Did you see the anything wrong with LED?
Then explain the LED operation to me. You reverse the polarity of the LED and it is basically in series with the relay coil and may glow faintly unless the transistor comes on in which case it will go out? Tell me what relay coil resistance you used in your simulation? For the LED to actually do much of anything the LED polarity needs reversed and the LED and series resistor should be placed across the relay coil. Then the LED will illuminate fully when the relay coil is active. So tell me what coil resistance you used for the relay as I want to simulate this circuit and see it work fine?yes, The LED should be connected in the opposite direction. I simulated the circuit by doing so and it works fine.
by Jake Hertz
by Duane Benson
by Duane Benson
by Aaron Carman
