1-bit ACD circuit
Discussion in 'The Projects Forum' started by thar07, Feb 16, 2015.
  1. thar07
    Jan 3, 2015
    71
    Can somebody post a 1-bit ADC circuits diagram with its components ?
  2. MrChips
    Oct 2, 2009
    12,646
    3,458
    Is this a homework question?
    Any digital input is a 1-bit ADC.
  3. thar07
    Jan 3, 2015
    71
    NO.
    I want a circuit diagram with its components.
  4. MrChips
    Oct 2, 2009
    12,646
    3,458
    I already gave you the answer.
  5. MrChips
    Oct 2, 2009
    12,646
    3,458
    If you want another answer, here is a circuit diagram:
    and another:
    and another:
  6. MrChips
    Oct 2, 2009
    12,646
    3,458
    We should invite Yakima the tutor to offer a solution.
  7. thar07
    Jan 3, 2015
    71
    How can I make circuit from above diagrams since you are not giving component models numbers ?
  8. ScottWang
    Aug 23, 2012
    4,933
    777
    What's the purpose of this 1 bit ADC, two bits have four status maybe more useful.
  9. MrChips
    Oct 2, 2009
    12,646
    3,458
    What is the transfer function of a 1-bit ADC?
  10. thar07
    Jan 3, 2015
    71
    I want to interface a LDR to this 1-bit ADC to get 0V and 5V outputs.
  11. thar07
    Jan 3, 2015
    71
    I have no idea about that.
    If you could just give me a circuit that only gives 0V and 5V as outputs when connect a LDR to its' input.
  12. MrChips
    Oct 2, 2009
    12,646
    3,458
    What is the resistance of the LDR?
  13. thar07
    Jan 3, 2015
    71
    Dark resistance = 1M
    light resistance = 500R
    "TORCH_LDR" in Proteus 8 software.
  14. mitko89
    Member
    Sep 20, 2012
    123
    19
    1-bit ADC o_O??? Comparator maybe?
  15. ScottWang
    Aug 23, 2012
    4,933
    777
    So you need a op amp schmitt trigger to set as voltage comparator.
  16. thar07
    Jan 3, 2015
    71
    Any circuit which only gives 0V and 5V as outputs when connect a LDR to its' input.
  17. thar07
    Jan 3, 2015
    71
    OK, If could please give me the circuit diagram of it with real components.
  18. ScottWang
    Aug 23, 2012
    4,933
    777
    You will need the circuit like this.
  19. thar07
    Jan 3, 2015
    71
    yes, with component vales and model names.
  20. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    thar07 likes this.
