I have been building this regulator for some years to charge a 12 Volt 7 Ah battery from a 20 Watt Solar Panel. It works quite fine.
In another posting I had Shown C1 and someone pointed out that it was not needed. Originally I had put it into the circuit with the idea of smoothing the incoming supply. If its not needed I will take it out to reduce the size but just want to confirm it is in fact not needed.
