1 acv to 10 acv step up
Discussion in 'The Projects Forum' started by aphinney, Mar 12, 2009.
  1. aphinney
    Mar 12, 2009
    5
    ok guys..looking to build a 1 to 10 acv step up. now i do not wanna do a transformer because of the lost over the transformer. here is the situation. we have a pc based dmm. it has a 10 acv max rating on it. we want to make this be 100acv max. so we are needing to build a 1 to 10 ratio acv step up. how can i do this. and once we get this built we are wanting to do a 1 to 10 ratio acv step up. thanx for the quick reply..
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Wait - you mean that you want a 10:1 reduction in voltage, right?
    If your PC based DMM only has a 10VAC max rating and you want to be able to measure 100VAC, then you'll need to scale the voltage down, not an increase in voltage.
    The most noise-free way to do that would be to use a 10:1 O-scope probe. You can buy them for around $10 on Ebay.
    If you're thinking of measuring any mains voltages though, you must use a transformer.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    The most efficient, lowest loss method of converting between AC levels is the transformer.
  4. aphinney
    Mar 12, 2009
    5
    yes sorry...im doin 100 things at once..yes i need a 10:1...so i can use a 10x prob wire into the pc based dmm leads and should work ? cause idk how that could work but i could be wrong
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    O-scope probe leads have a BNC male (coaxial bayonet) base. You would need a BNC female connector to banana plugs (or whatever your DMM connections are) or a "BNC female breakout".
    Sorry, I forget that not everyone has those kinds of things lying around in boxes. :rolleyes:
    If you're only going to be measuring 50Hz to 60Hz VAC, your safe and easy solution will be a transformer. However, if you're going to be measuring other frequency VAC, you'll need a different approach.
  6. aphinney
    Mar 12, 2009
    5
    well we are goin to need to be able to measure from 20Hz to 100Hz VAC
  7. aphinney
    Mar 12, 2009
    5
    so what are my options now...if i can get the probe to work...shouldnt have a problem with those freq should i ?
  8. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    For measuring those frequencies, the 10:1 probe is a good choice.
  9. aphinney
    Mar 12, 2009
    5
    thanks guys
