Hi all,
I would be very grateful if someone could steer me in the right direction. I have replaced a single phase motor on a stone saw bench. The original motor had been replaced and the replacement is just wrong too small etc. So I have replaced this with a capacity start and run 1.5 kw single phase motor 2800rpm. My question is what type of switch do I need for this type of motor, is a DOL start type switch needed even though the motor has the capacitors to start and run the motor.
Thanks in advance.
Thanks in advance.
