1.5 Volts Lithium batteries
Discussion in 'Off-Topic' started by bertus, Sep 12, 2014.
  1. bertus
    Thread Starter Administrator
    Apr 5, 2008
    15,805
    2,389
    I have seen lithium batteries in the size of AA and AAA that give out 1.5 Volts.
    The seem to have a regulation circuit in them with current limiting.
    Here I found the manufacturers website:
    http://www.iiquu.com/en/lithium
    Bertus
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Not rechargeable though.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    The problem is hard standards, they will not stop being standards just because tech moves on.
  5. #12
    Nov 30, 2010
    16,704
    7,351
    I can certainly imagine several good uses for a 5 volt battery the size of a AA.
    Lots of back-up batteries and portable instruments would like that kind of power source.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    4X AAA 1.25V batteries would do it. :)
  7. Brownout
    Jan 10, 2012
    2,375
    998
    So would a 1.5v battery and joule thief. That's what was in the first LED headlamp I had.
  8. #12
    Nov 30, 2010
    16,704
    7,351
    Yeah, I know. I already find (3) AA batteries in a lot of digital thermostats, but a 5 volt battery the size of a single AA battery would reduce the size and probably lower the cost. Then there are digital multi-meters that would like 5 volts for their logic circuits instead of stepping down a 9V battery.
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    And thus, a new standard is born. I've been seeing several new types of rechargeables in the last year.
  10. Georacer
    Nov 25, 2009
    5,151
    1,266
    Given the amount of 5V circuits in the tinkerer community, I also wonder why there isn't a 5V battery as well. There would be as much use for it, as there is for the 7805 regulator now.
  11. ISB123
    May 21, 2014
    1,240
    531
    They probably have reason for that.
    If they produce 5V battery 7805 sales would drop but if they keep 9V battery then they got a sweet spot since you need 9V and 7805.
  12. tcmtech
    Nov 4, 2013
    2,113
    1,752
    The potentially fatal flaw I see in making a direct 5 volt battery is voltage sag issues. Most 5 volt powered logic circuits tend to be rather fussy about how far above or below the 5 volt ideal they use you can go.
    As far as low power compact sized goes two 3 volt lithium button or coin cells plus a set of surface mount diodes tends to get you pretty close to that 5 volt working range with minimal power loss all in as tiny of package as you want.
    Georacer likes this.
