0-99 Counter Circuit :)
Discussion in 'The Projects Forum' started by DXJohnPaulXD, Jun 8, 2016.
  1. DXJohnPaulXD
    Jun 8, 2016
    23
    Hello guys my name is John Paul, do guys have any idea how to make a 0-99 up/down counter with a common cathode display?
    also can you tell me guys where to put a schmitt trigger to prevent button bouncing?
    i cant find a 0-99 counter using IC 4510 and 4511 or IC 7490 and 7447
    i want it to count up and down using a button ;)
    and i cant find any simple schmitt trigger circuit :(
    Any Help would be very Appreciated :)
  2. bushrat
    Member
    Nov 29, 2014
    97
    23
    Googled "0-99 bcd counter", first image shows what you need..
    Well, at least counting one way..
    mushir3000 likes this.
  3. ScottWang
    Aug 23, 2012
    4,925
    777
    Add an cmos TLC555 set to the monostable to be the debounce component, the delay time setup as 50mS, the pin 3 connect to the clock input of CD4510.
  4. DXJohnPaulXD
    Jun 8, 2016
    23
    Oops 7448 ic is not available in the store
  5. DXJohnPaulXD
    Jun 8, 2016
    23
    Thanks for the reply but i am finding easier ways for a debounce circuit
  6. DXJohnPaulXD
    Jun 8, 2016
    23
    How about using ic 4510 and ic 4511? (Sorry if im bugging you =) )
  7. DXJohnPaulXD
    Jun 8, 2016
    23
  8. dl324
    Distinguished Member
    Mar 30, 2015
    3,375
    651
    Similar circuit. TI datasheet has examples for synchronous and ripple clocking.
  9. dl324
    Mar 30, 2015
    3,375
    651
    Only counts up.
    Just design your own using whatever up/down counter you buy. Not that difficult and most datasheets will have application suggestions.
  10. hp1729
    Nov 23, 2015
    2,084
    232
    Something like this? I haven't built it yet but it should work.
    DXJohnPaulXD likes this.
  11. DXJohnPaulXD
    Jun 8, 2016
    23
    Exactly! :D i will just wait for you to test it :D
  12. DXJohnPaulXD
    Jun 8, 2016
    23
    Ok, Thanks :)
  13. DXJohnPaulXD
    Jun 8, 2016
    23
    Wait a minute. Did your circuit say to use the 4510 IC to be schmitt trigger?
    If 4510 ic is the schmitt trigger then how do i connect it?
    Show the pic of ur design on breadboard ;)
    I forgot to say im a 10 yr old kid lol
  14. DXJohnPaulXD
    Jun 8, 2016
    23
    UPDATE: it was a cd40106 ic (my eyes betrayed me) when i looked at its datasheet it was made out of schmitt symbols (schmitt trigger?) but i found another ic called 74hc14....so maybe i can subsitute the CD40106 with a 74HC14?
    Even if one of them is an inverted schmitt trigger
  15. ScottWang
    Aug 23, 2012
    4,925
    777
    How wonderful a 10 years old kid joined the forum, really welcome... :)
    And you preferred the 14 pins ic then a 8 pin cmos TLC555, you like big size?
  16. dl324
    Mar 30, 2015
    3,375
    651
    Didn't realize you were only 10; not many children can read schematics and datasheets:)
    Here's a schematic using CD4510 and CD4511. I just drew it and haven't tested, but it should work.
    Post here if you have issues or questions.
  17. dl324
    Mar 30, 2015
    3,375
    651
    They're both schmitt inverters and logically equivalent, but CD parts can operate from 3-15V while 74HC operate from 2-6V.
    There are many different 74 series hex schmitt inverters: 7414, 74LS14, 74HC14, 74HCT14, 74AC14, 74ACT, ... They differ in supply voltage, speed, fanout, input/out characteristics.
  18. DXJohnPaulXD
    Jun 8, 2016
    23
    Tlc555 is not available in the store so i chose the other one ;)
    EDIT: Im gonna use the NE555 timer instead of the tlc555 is that ok?
  19. DXJohnPaulXD
    Jun 8, 2016
    23
    Oh ok then i will choose cd40106 tnx ;)
  20. DXJohnPaulXD
    Jun 8, 2016
    23
    Guys if i use a ne555 timer how do i make it count at the normal speed and only up to 24? (Like a shot clock) :)
