0 - 5 vdc Ramp up Generator
Discussion in 'General Electronics Chat' started by Macka, May 3, 2012.
  1. Macka
    May 3, 2012
    Hi Anyone
    I need to build a 0 to 5 Vdc Ramp-up Generator with adjustable Ramp up time. The unit needs to be resettable each time any selectable voltage is applied via switch (Push Button). The selectable switch inputs are 1, 2, and 4.5 vdc approximately and are also adjustable.
    If required there is a 24vdc supply available.
    In summary when each Input button is pushed for what ever the output voltage is selected then that voltage should be the reference maximum voltage for the Ramp Generator to achieve. In other words if I was to select say the Mid Range Switch (2 vdc) then the Ramp Generator would need to increase the ramp up voltage from 1 vdc to 2 vdc. Realising that the previous 1 vdc switch has already been applied.
    The unit needs to be sequential on each Push Button selection either increasing voltage or decreasing.
    I look forward to suggestions and circuit.
    Macka
  2. jwilk13
    Member
    Jun 15, 2011
    228
    12
    I would use a microcontroller if it were me, but that's because I'm most familiar with those. I would get one with dedicated hardware PWM (like a PIC18F45K20).
    Are you familiar with using something like this? If so, I can give a "here's what I would do" rough description, but I don't want to explain something you're not familiar with.
  3. Bernard
    Aug 7, 2008
    4,237
    414
    Is a + 5V supply available?
    Switches are SP-ST-NO ?
    Does 0 V have a switch & does it also need to ramp down ?
    Approx ramp time ?
    What is max required output current ?
  4. strantor
    Oct 3, 2010
    4,302
    1,989
    check out attachment
  5. Bernard
    Aug 7, 2008
    4,237
    414
    A quick outline of a possible solution: Selected SW is stored in R-S reg., Q out selects pre-programmed logic switch, LS. For simplicity only 4 bits shown.LS programmed with dip-switch 4 to 8 bits. A digital comparator looks at LS & UP-DN counter, directs count direction, or stops count if =. UP-DN C also feeds D to A converter. A buffer supplies required current.
