0-10V with 12V PSU
Discussion in 'The Projects Forum' started by tmvvk, Apr 3, 2014.
  1. tmvvk
    Apr 3, 2014
    I'm currently working on making a simulation for the 0-10V analog inputs on the Zelio PLC. It's being fed with 12V and I'd like to make a simple regulator from 0-10V. Sadly I've forgotten most about constructing circuits.
    Would the TS7800 with a potentiometer work?
    Anybody that can help?
    Greetings,
    Thomas
  2. GopherT
    Nov 23, 2012
    6,340
    4,094
    Use an LM117 or LM 317. Unfortunately, this chip will only get you down to 1.25 volts in a simple circuit.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    How low does the output realy have to go?
  4. tmvvk
    Apr 3, 2014
    I need 2-10V (adjustable to x.1V). Can someone tell me the component values needed in this (example) schematic for that purpose?
    In = 12V
    Thanks loads.
  5. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,710
    1,302
    Metalmann likes this.
  6. KMoffett
    Dec 19, 2007
    2,586
    234
    What model Zelio PLC are you using? If the Analog inputs are high impedance, you only need a pot and a resistor.
    Ken
  7. crutschow
    Mar 14, 2008
    13,524
    3,392
    The LM317 needs about 3V minimum for regulation, thus the maximum output voltage with a 12V input would be about 9V.
    If the PLC input impedances are relatively high then just use a pot as Ken suggested. A 1kΩ pot, for example, has a maximum output impedance (at midrange) of only 250Ω. If you need a lower output impedance than that, you could use a rail-rail opamp follower at the pot output.
    If you wanted to get fancy, then you could use a 10-turn 1kΩ pot with a 10-turn dial to give better than 10mV resolution. If you add a 500Ω trimpot in series with the 10-turn pot than you can calibrate it so that 1 turn of the 10-turn pot equals 1V.
  8. AnalogKid
    Aug 1, 2013
    4,710
    1,302
  9. crutschow
    Mar 14, 2008
    13,524
    3,392
    You have a question, grasshopper? At midpoint the wiper is looking at two 500Ω resistors that are in electrical parallel, assuming one goes to ground and the other goes to a low impedance source. I leave it to you to do the math.
