Hello
In the place I work we purchased 2-10v actuators but have 0-10v controller.
The easiest would be to change the actuators bot I was wondering if someone here has an idea...
What I need is a circuit that will amplify a 2v input to 3v but wont amplify any input greater than 3v. doesnt have to be precise.
I have 24vac to work with.
For those who are interested it is an actuator of a water valve on an air conditioning system. What is happening now is that when the controller outputs 1V for example (when temerature is around setpoint) instead of letting through a bit of water it doesnt do anything at all.
I can set the controller to put out 5 steps of 2 volts but in the lowest step it still wont do anything. That is why I was thinking maybe it can be solved.
And that is why I dont need it to amplfy above 4V
thanks for reading
thanks for reading
