0-10 vdc to 0-5 vdc
Discussion in 'The Projects Forum' started by gamal eldeen, Mar 31, 2013.
  1. gamal eldeen
    Mar 31, 2013
    5
    I have an active sensors that have a 0-10V output can not be directly connected to a controller with a 0-5V input, what resistors and settings are required?
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
  3. gamal eldeen
    Mar 31, 2013
    5
    my controller has an analog input 5v with Current input (0 - 20 mA) using
    external 250 ohm resistor.
    what is the values of the resistors (as i want to work properly)
  4. KMoffett
    Dec 19, 2007
    2,584
    234
    What is the output current drive capability of the 10V sensors?
    Ken
  5. gamal eldeen
    Mar 31, 2013
    5
    Load resistance..................> 10 kOhm
    Current consumption, typical............15 mA
  6. nerdegutta
    Dec 15, 2009
    2,565
    805
    I think it would help everybody if you told what kind of sensor it is, with datasheet, and what kind of controller you have. With datasheet.
    Then we don't have to do a lot of guessing and asking questions...
  7. crutschow
    Mar 14, 2008
    13,486
    3,371
    If the load resistance for the sensor is >10kΩ then you could use two 10kΩ resistors in series to ground to provide a 20kΩ load and an output at their junction of 1/2 the sensor output.
    That should work provided the highest signal frequency is no more than a few tens of kHz.
  8. gamal eldeen
    Mar 31, 2013
    5
    the sensor is a pressure transmitter wet media spp110
    and the controller is schneider controller b3600
  9. gamal eldeen
    Mar 31, 2013
    5
    advise please...
  10. crutschow
    Mar 14, 2008
    13,486
    3,371
    What's wrong with my advice? :confused:
  11. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It must be the avatar. Looks kinda disreputable to me.:D
  12. crutschow
    Mar 14, 2008
    13,486
    3,371
    I resemble that.
