I know load resistors can be used for AC or DC application, but for accurate measurement and reading, should we use in separate application for AC or for DC voltage?
For example: If I have a Coil Resistor rating 660W, 120vac, this is a load for AC application. If I use this AC load (660W, 120vac) to connect 54Vdc system, what is the disadvantage for measurement or affect anything? Should be used or not recommend for using?
