This is an ambitious project, but still accessible for beginners. This particular project uses the LM1036 chip as audio control (volume, balance, bass and trebble) and uses a pair Visaton FR 10 4 OHM full-range drivers. These drivers have a good sound quality, but unfortunately they are not magnetically shielded, so cautions must be taken when using them near a CRT monitor, TV or any other device containing a CRT.
The amplifier is able to deliver about 4W each channel, and has a distributed gain per channel of 22.21dB (12.89V/V). However, when the balance control is taken to one of its extremes, the channel has an effective gain of 23.79dB (15.47V/V). The predicted frequency response is 60-20000Hz (-10dB).
List of components:
C1 4.7mF electrolytic capacitor (25V);
C2/14/23 - 10nF polyester capacitor (63V);
C3/4 - 100mF electrolytic capacitor (25V);
C5/6/20/29 100nF polyester capacitor (63V);
C7-10 220nF polyester capacitor (63V);
C11 47µF electrolytic capacitor (25V);
C12/21 10µF electrolytic capacitor (25V);
C13/22 330nF polyester capacitor (63V);
C15/24 - 470nF polyester capacitor (63V);
C16/25 2.2µF electrolytic capacitor (6.3V);
C17/26 33nF polyester capacitor (63V);
C18/27 470µF electrolytic capacitor (25V);
C19/28 1mF electrolytic capacitor (25V);
D1 1N5400 rectifier diode;
D2 - Red LED (GaAsP/GaP)
FTE1/2 Full-range speaker Visaton FR 10 4 OHM;
HS1/2 - 10ºC/W passive heatsink (for TO-220);
IC1 LM1036 audio control;
IC2/3 TDA2003 audio power amplifier (with 10ºC/W heatsink);
J1 - 5.5mm x 2.1mm DC socket;
J2 - 3.5mm TRS socket (stereo phone socket);
J3/4- RCA socket;
JW - 26AWG stranded wire;
R1 680Ohm carbon resistor (5% tol., 1/2W);
R2/4/6/8 47K potenciometer (10% tol., 1/8W);
R3/5/7/9 47K carbon resistor (5% tol., 1/8W);
R10/17 1K carbon resistor (5% tol., 1/8W);
R11/18 2.7K carbon resistor (5% tol., 1/8W);
R12/19 390Ohm carbon resistor (5% tol., 1W);
R13/20 47Ohm carbon resistor (5% tol., 1W);
R14/21 220Ohm carbon resistor (5% tol., 1W);
R15/22 2.2Ohm carbon resistor (5% tol., 1/8W);
R16/23 1Ohm carbon resistor (5% tol., 1/8W);
S SPST switch.
Electrical parameters:
- Vd min = 9.80V
- Vd max = 15.72V
- Id (Vd = 13.5V) = 887.5mA
- P (Vd = 13.5V) = 11,98W
Amplification characteristics (each channel):
- Input impedance: 967.7Ohm
- Gain (pot R4 centered): 22.10dB (12.75V/V)
- Gain (pot R4 all to left or all to right): 23.69dB (15.29V/V)
- Output power (Z FTE = 4Ohm): 4.7W
Audio characteristics:
- Frequency response: 60-20000Hz (-10dB)
- Sound pressure (SPL): 92.70dB (each channel)
Recommended enclosure specifications:
- Type: Ported (4th order Chebychev alignment)
- Volume: 6,319L
- Recommended duct: Monacor BR-30HP (length: 56mm)
- Resonant frequency (Fb): 68.494Hz
- -3dB frequency (F3): 59.984hz
Translations:
- Agudos - Treble;
- Alimentação 13,5V CC - 13.5VDC supply;
- Balanço - Balance;
- Canal direito - Right channel;
- Canal esquerdo - Left channel;
- Entrada de áudio estéreo - Stereo audio input;
- EDM - Short for left, right, ground (LRG);
- Graves - Bass;
- Positivo - Positive (V+);
- Secção - Section;
- Secções - Sections;
- Volume - Volume (no translation here).
Important: When printing the PCB and the panel prints, print them in real size. This is a requirement, even if you print in A4. Some printers will reduce to fit. This procedure should work for both A4 and Ansi A (8.5" x 11") formats. The PCB should measure 120mm x 131mm.
List of components:
J3/4- RCA socket;
S SPST switch.
- Vd min = 9.80V
- Vd max = 15.72V
- Volume: 6,319L
Translations:
- Agudos - Treble;
- Graves - Bass;
- Secção - Section;
