I don't get why the electrons are able to go through the depletion layer when the negative terminal of a battery is connected to the N type.
Also If I connect the + terminal of the battery to the N type and the - terminal to the P type. The depletion layer will eventually be the whole diode, right ? I mean it expands till it's full ?
