| Programmer's Corner Discussion forum for all aspects of programming and software engineering. Any software programming language welcome: C, C++, C#, Fortran, Java, Matlab, etc. |
Thread Tools | Display Modes |
#1
I was assigned to make 4 programs that will satisfy the asked outputs and is to be programmed on PIC. (sadly i wasn't able to attend our scheduled seminar regarding PIC programming due to time restraint. so i thought of coming here again and would like to ask for help. I'd be thankful if you could help me with my project.)
1.) Running Light that will turn on/off all leds Given were 8 leds with a time delay. Cycle 1: 1 2 3 4 5 6 7 8 = on Cycle 2: 1 2 3 4 5 6 7 8 = off 2) Running light that will turn on/off led one at a time Cycle 1: 1 = on | 2 3 4 5 6 7 8 = off Cycle 2: 2 = on | 1 3 4 5 6 7 8 = off Cycle 3: 3 = on | 1 2 4 5 6 7 8 = off Cycle 4: 4 = on | 1 2 3 5 6 7 8 = off so on and so forth... 3) Running light that will turn on odd turn off even leds and vice versa Cycle 1: 1 3 5 7 = on | 2 4 6 8 = off Cycle 2: 2 4 6 8 = on | 1 3 5 7 = off 4) This time running light that will turn on/off led one at a time AND THEN runs reversed Cycle 1: 1 = on | 2 3 4 5 6 7 8 = off Cycle 2: 2 = on | 1 3 4 5 6 7 8 = off Cycle 3: 3 = on | 1 2 4 5 6 7 8 = off Cycle 4: 4 = on | 1 2 3 5 6 7 8 = off so on and so forth... Cycle 9: 8 = on | 1 2 3 4 5 6 7 = off Cycle 10: 7 = on | 1 2 3 4 5 6 8 = off Cycle 11: 6 = on | 1 2 3 4 5 7 8 = off Cycle 12: 5 = on | 1 2 3 4 6 7 8 = off |
#2
I don't do PIC, but can imagine the hundreds of similar projects on the web, if not here in this forum. Have you tried the search function, or Google? You didn't mention what language, or which compiler. By the way, this is so insanely simple, you should be ashamed of yourself for asking.
Just in case no one here is feeling like showing some pity, and taking 15-20 minutes writing your homework for you... Will help you get started on your own. First, get the datasheet for the PIC you intend to use, need at least 8 I/O pins. Next, search the web for a beginner's tutorial in which ever language you plan on using. The very first thing most every tutorial start with, set a port/pin for output, and flashing an LED. If you can flash one LED, it's simple to flash 8. I did the night-rider one as my second program when I started AVR, took about 20 minutes in assembly. I hadn't programmed anything since the late 80's. For the most part, if you start a project before asking for help, you will get dozens of replies, helping you fix the code/circuit you post. Skipping class, then asking strangers to do the work for you... |
#3
Yes it can be done through assembly language. Sorry I just don't want to practice this and i'm not into programming. PIC16F84A is the used PIC.
http://ww1.microchip.com/downloads/e...doc/35007b.pdf Last edited by markidgmgig; 03-01-2008 at 12:13 PM. |
#4
If you really expect to get help, you need to at least get started on it, and post the code you have so far. I don't use PIC, but I have used PIC tutorials to get some insight on how to do a few things. I know just enough PIC stuff, that I might struggle through doing it in assembly, and I've never used one. PIC only have 32 instructions, and one register. No big deal with a high level language, like 'C', and probably not so bad once you've get a good collection of routines. I chose AVR, because it seemed a little more friendly for assembly, with 130 instructions and 32 registers.
In my first reply, I gave some direction on how you can get started on your own. Seriously, search the web, you might find the exact program you are looking for, or something very close. Whether you are 'into' programming or not, you will need to start some place. I could post the code for my AVR running lights, but it wouldn't do you much good. Seriously, this isn't that bad. If you know a little programing, you can do this. |
| Tags |
| led, light, project, running |
Related Site Pages
| Section | Title | |||
| Worksheet | Microcontroller principles | |||
| Worksheet | Timer circuits | |||
| Worksheet | Digital display circuits | |||
| Worksheet | Design Project: Logic probe | |||
| Worksheet | Thyristor application circuits | |||
| Worksheet | Oscillator circuits | |||
| Worksheet | Bipolar junction transistors as switches | |||
| Textbook | CMOS 555 LONG DURATION MINIMUM PARTS RED LED FLASHER : 555 Timer Circuits | |||
| Textbook | Special-purpose diodes : Diodes And Rectifiers | |||
| Textbook | Conversion from decimal numeration : Numeration Systems | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Bell222 strobe light project | vane | The Projects Forum | 28 | 01-11-2008 04:46 PM |
| 12/24V Incandescent Light Bulb Dimmer to drive MR-16 LED Lamp | monkey19939 | The Projects Forum | 5 | 07-25-2007 12:46 AM |
| LED Dimming in Parallel | pfhorge | The Projects Forum | 6 | 02-27-2007 07:36 PM |
| need help - led light project | euigean | The Projects Forum | 1 | 02-13-2007 04:22 PM |
| Thread Tools | |
| Display Modes | |
