Hard problems in Computer architecture
nhaldipuri
Joined Apr 6, 2014
5
1. a) The first access to any cache block/page results in a miss, and called "compulsory misses' - "these are truely compulsory only if we follow on-demand fetching" - Explain.
b) A program accesses each element of a 1024X1024 matrix 8 times in each course of its execution. If the data cache can accommodate 256 matrix elements and 16 matrix elements per block/page, then how many compulsory data cache misses will be caused by this program's execution ?
2.Illustrate the 'diagonal format of encoding micro-instructions for a micro-programmed control unit with an example. Find out the cost optimal micro-instruction format for a system with the following set of micro-instructions and controls. Ensure minimum length of the micro-instruction format as well as the maximum parallelism among the micro-operations.
Microinstructions Control signals
I1 b, e, f
I2 a, b, c, d
I3 a, b, e, h
I4 b, e, g
3.A m/c is being designed whose instructions range from 1 to 6 bytes in width, with 2-bytes instruction being most common and 5- or 6-byte instruction rarely used. Compare the following opcode encoding schemes-
i. The leftmost 3 bits in the first byte of every instruction contains a binary number (1 to 6) that indicates the width of the instruction in bytes.
ii. One-byte instructions begin with 0 in the leftmost bit position of the first byte, 2-byte instructions begins with 10, and all other instructions begin with 11 followed by a 2- bit field that indicates the number of additional bytes (beyond the third) in the instruction.
30,824
Then what is your question?
In Homework Help, we do not do your homework for you.
Show your own answers and then we would be in a better position to help you.
nhaldipuri
Joined Apr 6, 2014
5
Please help.
1. A program accesses each element of a 1024X1024 matrix 8 times in each course of its execution. If the data cache can accommodate 256 matrix elements and 16 matrix elements per block/page, then how many compulsory data cache misses will be caused by this program's execution ?
Ans: Now , I have assumed the following things:-
i) The Main memory size is 1024X1024Xsizeof(int).
ii) The number of blocks in cache is= 256/16=16.
iii) The access is row-wise means
array[0][0],[0][1],…[0][1023]
[1][0],[1][1],…[1][1023]
[1023][0]……….[1023][1023] are accesed sequentially one after another.
iv) 8 acceses are also sequential:- means first all the elements are accessed one time then again accessed,again,…until the number of access is 8.
v) Also I have considered that the scheme for mapping is “Direct Mapping.
Now ,there are 256/16=16 cache line.Each contain 16 array elements.[numbered 0,1 ,2 ,3,4 ,… ,15].
There are (1024X1024)/16 =65536 main memory blocks.[ block number is 0,1,2,,3,4,……..65535.]
First time [0][0] element will not be there in cache.The whole line of MM numbered 0 will be fethed in cache 0 line. There will be no miss for next 15 elements as they are already in cache.
In 16 elements there are 1 cache miss. There are 16 misses in accesing 256 array elements. There are 1024X1024 elements accessed at a time. There are (1024X1024/256)=4096 cache misses.
The number of misses in 1 whole access of 1024X1024 elements is 4096.
For 8 whole access ccache miss=8X4096=32768.
Now Is my answer correct? Please help if there is anything wrong. I will be satisfied if one can give a better solution with a different approach.
