All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-24-2008, 05:23 PM
mer584 mer584 is offline
Default Capacitors and finding Voltage
Problem: A 3.00uF and a 4.0uF capacitor are connected in series and this combination is connected in parallel with a 2.0uF capacitor. If 26V is applied across the whole network, calculate the voltage across each capacitor. (See attached figure)
My Attempt/Questions:
So my thought was to find the total charge and the total capacitance and use V= Q/C to find the voltage across each
so the total capacitance will be 1/(.33 +.25) +2 = 3.71uF
then the total charge by Q=CV = 3.71 x 26 = 96.5 uC
so the voltage at 2.0uF capacitor will be V=Q/C = 96.5/2 = 48.2V
What I don't get now is how I relate what I know to the remainder of the parallel series at the top of the box. I know that the voltage wont be split evenly between them, but that they will share the same amount as the one in parallel. That is to say capacitor 3.0 and 4.0 should have a cumulative voltage of 48.2V but that it wont be split evenly between them.
Is this correct, and if so how do I go about calculating that? Thanks
  #2
Old 02-24-2008, 08:42 PM
spar59 spar59 is offline
Member
Default
If the only answers required are the voltages across the capacitors then from the circuit diagram the voltage across the 2.0F capacitor is already shown as 26V - no calculation required! Ignore the 2.0F capacitor and concentrate on the voltages across the remaining 2 capacitors.
P.S. is the voltage AC or DC - if it is the latter then in a practical circuit after the initial charging period the voltages will be governed by the relative leakage currents rather than relative capacitance. If it is AC then consider it as a potential divider using the reactance of the capacitors ( 1/(2.Pi.f.C) )- the frequency doesn't matter, just use a variable f - since it will cancel out in the calculation anyway.
Steve.
  #3
Old 02-24-2008, 10:37 PM
Default
I've never seen that formula before I don't think we've learned it yet. Why, or how can you tell that this will be an alternating current??
I can understand now why it is 26V across the middle capacitor at least. Which would make me correct in assuming that the other branch is cumulatively going to be the same aka 26V?? But i havent made any progress towards the latter half
  #4
Old 02-25-2008, 10:32 PM
Member
Default
The reactance (similar to resistance) of a capacitor is as given by the formula stated - if you haven't met it before then I shall point you to the site's E-book page for more information since I was struggling to find the appropriate symbol for Pi.
http://www.allaboutcircuits.com/vol_2/chpt_4/2.html
Unfortunately the diagram you provided does not specify A.C. or D.C. which is a rather large omission.
Steve.
Tags
Related Site Pages
Section Title
Worksheet Algebraic substitution for electric circuits
Video Lecture Capacitors (Part 3) - Series and Parallel Connections - Inductors,Capacitors,Transformers
Worksheet Multi-stage transistor amplifiers
Worksheet Series-parallel combination AC circuits
Worksheet Resonance
Worksheet Capacitors
Textbook Calculating power factor : Power Factor
Textbook Q and bandwidth of a resonant circuit : Resonance
Textbook Series resistor-capacitor circuits : Reactance And Impedance -- Capacitive
Textbook AC capacitor circuits : Reactance And Impedance -- Capacitive
Similar Threads
Thread Thread Starter Forum Replies Last Post
Calculating inductance values and other questions on capacitors HenryG40 Homework Help 2 01-13-2008 08:25 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
