Not sure if this is the best medium to seek answers for a MRI physics, but heck, I'll try.
Unfortunately, I am having trouble grasping the idea of K-space.
From what I have understood, the echo of the MR signal is measured while the frequency encoding gradient is on. This whole process (including the 90deg RF pulse, 180deg pulse, and slice-select) is repeated for every phase encoding gradient increment.
A given row in K-space then corresponds to an array of samples that is a digitized version of the MR signal measured during the frequency encoding stage.
What confuses me is when the sources that I have read state that K-space is a collection of raw complex data. How can it be complex if each row is a sampled real MR signal? Shouldn't the image be complex because you take the 2D-FFT of the real K-space to obtain an image?
Cheers!
Cheers!
