I made a couple of PCBs using toner transfer method. After I assembled the parts and soldered it to the pads, when i touch the components with a little force, the pads came off and the component starts shaking. Is it the problem of the copper clad board or is it because I used a 1mm bit to drill the holes so there was no friction between the component lead and the board?
