New guy here, so please go easy on me
It's my second night on the easyPIC and I think madam is angry.
But I managed to write what I need on the default PIC & LCD. i.e Stop the scrolling and add delays. And switch the Display from three different sentences as such.
So far so good.
My aim was to Display and read ADC.
I thought why not go for the PIC that I would be using for my project not the big 40pin one.
After searching I found the obvious one. A 16F88. Enough ports for 16*2 LCD and analog ones for ADC, two total I needed.
Went through the collection and luckily I had two.
So now to code for the 16F88 in C. Took me while but managed to change the code and programmed and works like charm.
Thought I'll check the second F88. plugged in and hit program and mikroProg gave me Vcc voltage error . Checked the PIC and it was HOT. I managed to put in reverse. Crap !
Took it out and I thought I will put it back again. So tried and to my surprise it's still working. These little bugger's are tough and so was the easyPIC. !!
Whew ! What a relief.
Now I am trying to read the ADC on AN0 and AN1.
I think I would need help but I will let you guys know after trying.
I thought a heads up would be worth it.
So far so good.
