All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-21-2008, 02:51 AM
mcghee.kevin mcghee.kevin is offline
Junior Member
Default 555 Timer operating a PNP transistor
Hi, just joined the forum. I am trying to build a timer, that after 5 minutes will turn on a buzzer.
My plan was to build a monstable 555 that when the output on pin 3 is high it would apply its voltage to the base of the pnp tranasistor which would turn the buzzer off, then when the 5 minutes are up (i have found the correct capacitor and resistor combination to do so) the output goes low and the pnp would have no power at the base and turn the buzzer back on.
I have both a functioning PNP circuit and a functioing monostable circuit but when i attach them together the 555 does not turn the pnp off... any ideas why, I am stumped.
  #2
Old 02-21-2008, 04:38 AM
Audioguru's Avatar
Audioguru Audioguru is offline
Default
The 555 has a darlington transistor output that has a high voltage that is 1.2V less than its supply voltage. The PNP transistor needs to have a base voltage that is at least 0.4V less than the supply voltage. Use a voltage divider to drive the base of the transistor or add two series diodes to its emitter.
A Cmos 555 like an LMC555, TLC555 and ICM7555 have outputs that go up to the supply voltage.
  #3
Old 02-21-2008, 07:20 AM
Junior Member
Default
thanks for the reply. First i would like to say that I am new to electronics although I learn quickly. My supply voltage is 9V and the output on the 555 is 6.4 volts if I remember correctly. I an unsure of what a voltage divider is or two series diodes to its emitter means... could you explain, perhaps post a schematic, I can understand a schematic very well.
  #4
Old 02-21-2008, 05:05 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Default
If you're only getting 6.4V out of your 555, there is a problem. Do you have a resistor between your 555 supply pin and the battery supply?
It would help if you posted a schematic of exactly what you have so far.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #5
Old 02-21-2008, 06:07 PM
Ron H's Avatar
Ron H Ron H is offline
Default
Why don't you just connect the buzzer between +9V and the output of the 555?
  #6
Old 02-21-2008, 07:00 PM
nomurphy's Avatar
nomurphy nomurphy is offline
Default
If the buzzer draws more than ~200mA at 5V, don't connect it directly. Try using the discharge out (pin-7) as in the attached. Or, if discharge is being used for the timer, you can also do the same thing with the pin-3 output.
  #7
Old 02-21-2008, 10:21 PM
Junior Member
Default
Quote:
ive tried that, when the output on pin 3 goes low and sinks to ground the buzzer comes on, when it goes high the buzzer is on but at a lower tone so that doesn't work
  #8
Old 02-21-2008, 10:22 PM
Junior Member
Default
No resistor between pin 8 and 9v+ I will be posting a schematic soon
  #9
Old 02-21-2008, 10:41 PM
Ron H's Avatar
Default
Quote:
So, do any of you guys understand how the 555 output can sink current when it's high? According to the schematic, it can't.
Kevin, are you using the same power supply for the 555 and the buzzer?
  #10
Old 02-21-2008, 11:32 PM
JoeJester JoeJester is offline
Default
Ron,
The only way it could sink current when it's high is the potential difference between Vcc and whatever the other potential the buzzer is connected.
I'd wait for kevin's schematic before trying to decipher anything else.
__________________
Joe
http://www.fcctests.com
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Simple 555 timer delay on circuit needed eatumup General Electronics Chat 3 02-21-2008 04:21 AM
quick 555 timer question skinner927 General Electronics Chat 10 01-24-2008 05:23 AM
How to construct a PWM circuit using 2 Timer 555 cloud623 The Projects Forum 12 12-27-2007 03:02 AM
difference between an analog multivabrator and a 555 timer multivbrator anilson General Electronics Chat 2 10-02-2007 02:06 PM
555 timer fsk generator problem nwo4life The Projects Forum 2 02-26-2007 02:13 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
