I am trying to construct a circuit diagram for a diesel generator power system. I have read quite a bit online about 3-phase, but I haven't found an explanation for what I am seeing:
The generator has only three leads. Between lead "A" and lead "B" I read 208 volts. Between "A" and "C" I read 120 volts and between "B" and "C" I read 120 volts.
I don't think these voltages are consistent with normal delta, high-leg delta or open delta, delta with a center tap on one phase, nor with a wye system. Incidentally, the generator powers 120V lights, some baseboard heaters of unknown voltage, and a big motor that is labelled "3 phase."
Can anybody tell me what connection arrangement I have?
Thanks in advance.
Thanks in advance.
