So suppose, ac input gives rms voltage x and after transformation through transformer to half wave rectifier circuit it gives voltage y. Now to get peak value of this, is the answer is √2y or 2y?Essential difference is whether one is referring to the rms value of the ac source voltage or the rms value of the rectifier output voltage.
If the rms value of the rectifier output voltage is known to be value 'y' then the peak value of the half wave rectified waveform would be 2y.So suppose, ac input gives rms voltage x and after transformation through transformer to half wave rectifier circuit it gives voltage y. Now to get peak value of this, is the answer is √2y or 2y?
by Jake Hertz
by Jake Hertz
by Jake Hertz
