Equivalent resistance as seen by the source
SilverKing
Joined Feb 2, 2014
72
Hi everyone,
The problem as shown in the attachment is to "Find the equivalent resistance as seen by the source VS (The resistance between a and b)"
The line "as seen by the source VS" is disturbing :S
So, is it only R1 or R1 and R8 and R7?
ericgibbs
Joined Jan 29, 2010
18,869
hi,
Calculate including ALL the parallel and series resistor network values and reduce the resistance to a single value.
Is this Homework, if yes, what do you calculate the equivalent resistance to be.?
E
LvW
Joined Jun 13, 2013
1,760
Silver King,
I think, your start (first attempt) as scetched on the right figure looks good.
However, two questions:
1.) "The line "as seen by the source VS" is disturbing :S"
What does this mean?
2.) What is the meaning of your question in red (right figure)?
SilverKing
Joined Feb 2, 2014
72
ericgibbs:
I didn't get your question, but if you're asking about the equivalent resistance, I'd say (depending on what you said) that it's equal to [(R2+R3+R4//R5)+R6+(R1//R7//R8)]
This is not a homework, but consider it like one
LvW:
1) I don't know if it's same when question says "Find the equivalent resistance" and "Find the equivalent resistance as seen by the source"
2) My question in red says: "Can I assume those points a and b?"
SilverKing
Joined Feb 2, 2014
72
ericgibbs:
So basically when I face a question like doesn't change the fact that I've to calculate all the resistance in the circuit?
and for R1//R7//R8, after second thought, it looks like that same current is passing through R8 and R7 which means that they're in series and their sum is in parallel with R1, am I right?
studiot
Joined Nov 9, 2007
4,998
This is not a problem it just works like this:
Take any two nodes in a circuit and draw a line ab through them.
The line divides the circuit into two halves, like a diameter divides a circle into two semicircles.
The important point is the the two halves of the circuit only connect at nodes a and b, they do not connect anywhere else.
For linear circuits there are three theorems all of similar form.
These say we may replace one half of the circuit withone or two components, depending upon circumstance.
Let us say we are going to replace the right hand side (RHS)
1) If there are no sources of electricity (batteries generators etc) in that half then we may replace the entire half circuit with a single resistance (impedence).
This is called the equivalent resistance looking from the left hand half of the circuit
The formulae for parallel and series resistors are simple examples of this.
2) If there are sources of electricity the we may replace the entire half circuit with a sinngle constant current source in parallel with a single resistance (impedence).
This is called Norton's theorem.
3) If there are sources of electricity we may replace the entire half with a single voltage source in series with a single resistance (impedence).
This is called Thevenin's theorem.
Note that we may do either of 2 or 3 so we have a way of providing
an equivalent source
ericgibbs
Joined Jan 29, 2010
18,869
hi SK,
Have you arrived at a final solution for the equivalent resistance.? if so, what is its value.?
E
SilverKing
Joined Feb 2, 2014
72
studiot:
First of all, I must say that this problem is under Series and Parallel resistances only, there should no use of any network theorem
In our case, we have a voltage source, can I assume that the equivalent resistance that voltage source sees (between points a and b) are the resistors that have same volts as the source? the ones in parallel with the source?
P.S. would you take a look at the attachment below? is the current division (which is upon it I calculate the total resistance) correct?
ericgibbs:
If my calculations in #6 are correct, then it would be equal to 50 ohms//R1=9.6 ohms
studiot
Joined Nov 9, 2007
4,998
(1) First of all, I must say that this problem is under Series and Parallel resistances only, there should no use of any network theorem
(2)In our case, we have a voltage source, can I assume that the equivalent resistance that voltage source sees (between points a and b) are the resistors that have same volts as the source? the ones in parallel with the source?
(1) Is not the replacement of 2 parallel resistors by one equivalent what you are talking about? I just thought you might like a wider view since I don't know why you are doing this.
(2) Definitely not, you need to take on board the first part of what I said even if you don't go as far as Norton & Thevenin.
The voltage source 'sees' either the original arrangement of resistors or something equivalent.
The something equivalent is any arrangement that will draw the same current from the voltage source.
There are an infinite number of possible equivalent arrangements.
The simplest one is a single resistor for which current is the same (by Ohm's law) as that drawn by the original arrangement.
ericgibbs
Joined Jan 29, 2010
18,869
hi SK,
I dont agree with your answer, but this may be due to me misreading the resistor values from your blurred drawing.
Can you confirm the values?
E
WBahn
Joined Mar 31, 2012
30,077
Hi everyone,
Maybe this will help you get the basic concept involved.
The source is hooked up to this mishmash of resistors. It connects to them at points 'a' and 'b' (the two terminals of the source). We can replace the mishmash with a single resistor and, if chosen properly, the source can't tell that anything has changed. As far as it's concerned, the single resistor and the mishmash are equivalent.
However, this is NOT to say that that same resistor is always the equivalent resistance of that particular mishmash. Imagine removing that source from the circuit and instead putting a different source that is connected between a different pair of points. It's the same mishmash, but we can't replace it with the same resistor that we did before. We need to choose a different value in order to make it so that the new source can't tell the difference.
While we may say things like, "that the source VC sees," what we really mean is more like, "that something connected between points a and b sees after removing the source VS." Both pieces are important -- knowing that we are talking about the source VC tells us which points we are interested it and it also tells us that we should find an equivalent that does NOT include the source VS itself.
SilverKing
Joined Feb 2, 2014
72
ericgibbs:
R1= 12 R2=16 R3=25 R4=50 R5=30 R6=7 R7=4 R8=16
studiot, WBahn:
After getting through what you said, I see that I'm starting to get the idea
ericgibbs
Joined Jan 29, 2010
18,869
hi,
This image shows the method I used, a couple of days ago, I misread the R2 value as 15R.
It should be easy for you to substitute the correct value in the equations.
Your answer should be 6R as opposed to mine of 5.98R
Do you agree.?
E
The Electrician
Joined Oct 9, 2007
2,970
hi,
Do you agree.?
E
You've got the right end of R6 connected to the right end of R1, but in the OP's original diagram the right end of R6 is connected to the junction of R7 and R8.
ericgibbs
Joined Jan 29, 2010
18,869
hi TE,
Woops, I will relook at the OP's original image.
Thanks for the heads up.;)
E
EDIT:
I see it now, duh!!!
SilverKing
Joined Feb 2, 2014
72
JoeJester:
No, I don't think so.
After getting through in the subject, I've seen that my problem was with identifying the nodes.
Please take a look at the attachment, the nodes which connects only two elements are just called "nodes",aren't they?
And the nodes which connects more than two elements are called "essential nodes", right?
So, taking in my mind that any two elements connected by a "node" are in series, and any two elements have two essential nodes in common are in parallel; the only two elements that have a and b (two essential nodes) in common are the voltage source VS and and R1 (R1=12 ohms).
How do you see my approach?
JoeJester
Joined Apr 26, 2005
4,390
There is nothing wrong with the way you did the node identification. Did you happen to notice that my drawing is your problem ... only redrawn for clarity?
SilverKing
Joined Feb 2, 2014
72
Of course I did notice that, just wanna make sure if my approach is correct or not.
So, If I have a question like this (to find Req), I'll take the nodes in priority, which results - in this case - not the combination of all the resistors in the circuit, but only between a and b, which is 12 ohm, right?
