Hi all,
I have a set up a basic boost circuit on a breadboard using TI's MC34063A IC. I designed the converter to operate using an input 9V alkaline battery that can droop down to 6V and have an output of 26V (100 mV ripple) with a max output current of 100 mA.
I chose components based on what I had on hand so the cap/inductor/resistor values are not exact. I had to make my own Rsc resistor by breaking apart wire-wound concrete resistor because I didn't have any sub an ohm. It's resistance is around 0.6ohm which is higher than I need but the best I could do for the moment.
Unloaded this operates with better than expected ripple and is bang on 26V. The moment that I load this with a load resistor of 1kohm or less, the battery's voltage begins to drop relatively quickly, either the diode or inductor get hot (hard to tell because its really cold in my apt and I have no feeling in my fingers) with a noticeable smell, and after a while a little bit of a high-pitched noise starts up. Doesn't seem to be the IC though.
The diode is rated at 1A/40V and the inductor is made of ferrite and rated at 180mA. I have a feeling this has something to do with the diode because I was reading -18V (anode to cathode) but the datasheet recommended using a toroidal inductor (which I don't have).
So I figure this is either an inductor current rating issue, something to do with the diode (Motorola 1N5819), my Rsc that I made is too large, or a wiring issue.
Wondering if anything sticks out to anyone. I have attached images of both the circuit and the wired breadboard (Rsc looks like a black jumper between pins 6 and 7).
Thank you,
JP
Thank you,
JP
