I need to design a simple IR detector circuit to measure the time delay between when a command is sent to a laser cutting machine (via a custom C# program) and when the laser actually fires. I'll be connecting channel 1 of a scope to the trigger input on the laser power supply and the detector circuit on channel 2 to determine the delay. I'm looking at the laser specs and it says the IR beam has an energy of 0.2 mJ with a pulse width of 4 ns. Is there any way to safely and accurately measure this pulse or is it too much power and/or too fast? According to my calculations, that is 50,000 W per pulse and the minimum repetition rate is 1 Hz, so that's 50,000W for 500 ms. We have some PIN diodes available (BPV10NF), but I'm not sure this is even feasible. It is a laser cutting machine after all.
