Yes, I forgot to attach it. I'll go back and do that. Thanks.Hello,
Do you have the schematic or a link?
Bertus
Sure but it's probably not as bad as it first sounds. Generally the ADC value is used for some real world task, and has to go through a scaling math procedure anyway (like; result = ADC *X /Y) which itself produces quantising errors. So in that case you can just include the calibration value as part of that scaling procedure.(re my suggestion); ... Yes, you could do some math and use a 5V reference, but I imagine there would be some quantization errors.
Why would you need 100X or even 10X? Just hang a bypass (energy storage) capacitor between the TL431 output and the reference input. If the Ref input pin draws a transient current larger than 150uA, it can come out of the capacitor. If you are worried about ESR in the capacitor, hang a low esr, low inductance disc ceramic across the larger capacitor......
Page 188 of the PIC 16F88 dtatsheet: Vref input current = 150 ua
Using my usual standards for a precision reference, 100 x 150 ua = 15ma
On a lesser quality job, 10X would be sufficient.
I agree with you fully on providing current just marginally higher than what is required, and not way higher than what is required.Why would you need 100X or even 10X? Just hang a bypass (energy storage) capacitor between the TL431 output and the reference input. If the Ref input pin draws a transient current larger than 150uA, it can come out of the capacitor. If you are worried about ESR in the capacitor, hang a low esr, low inductance disc ceramic across the larger capacitor...
Thread starter | Similar threads | Forum | Replies | Date |
I | Question about voltage reference circuit | Homework Help | 2 | |
M | 68HC11 question: ADC reference lines | Microcontrollers | 2 | |
D | Voltage reference question | General Electronics Chat | 10 | |
K | quick question about picking the reference | General Electronics Chat | 3 | |
D | Cross-reference question | General Electronics Chat | 1 |
