All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 12-13-2013, 05:06 PM
Morpho Morpho is offline
Junior Member
Default Science Fair Project Help
To make a long story short, Iím having trouble helping my son with his science fair project. We decided to look at the relationship between resistance and the life of an LED. I wired 8 LEDís in parallel (thereís no significance to the number 8, itís just the number of LEDís I had in the box that were all 1.9V and 20mA) with 8 different resistors (0, 1, 10, 33, 82, 220, 510 and 1K ohms). Iím using a DC power source thatís putting out 14.6V. I figured I could wire the LEDís in parallel and avoid having to provide 8 separate power supplies. I expected the 4 LEDís below 82 ohms to burn out and the other 4 to continue to be lit for the duration of the experiment. However, when I built the circuit, none of the LEDís light at all. I suspect I'm missing something basic and any help or ideas would be greatly appreciated.
  #2
Old 12-13-2013, 05:09 PM
mcgyvr mcgyvr is offline
Default
Do you have them wired backwards? They are polarity sensitive..
  #3
gerty gerty is offline
Default
The first thing I would check is the polarity of the leds.
That is of course that you're certain they're good.
Beat me by a few seconds..
  #4
Old 12-13-2013, 05:14 PM
Junior Member
Default
Checked with a 1.5V battery for polarity and they light.
  #5
Old 12-13-2013, 05:36 PM
Default
Usually connecting a led to a battery without a current limiting resistor is fatal to the led. Yes it'll light up the first and maybe second time, but it usually won't live long after that.. Kinda like striking a match to see if it's good, it'll never strike the second time.
  #6
Old 12-13-2013, 05:56 PM
JohnInTX's Avatar
JohnInTX JohnInTX is offline
Default
What is your DC source? With a power supply and your hookup, it may be that it goes into current limit. If its a foldback current limit, it will drop the applied voltage until the overload is reduced. With 0 ohms, you've essentially shorted the supply. If the LED fails shorted, the others won't light.
If the source is a battery, it also may not have the current capacity to overcome the overload.
Have you measured the voltage on the 14.6V bus when its not lighting?
__________________
We learn to do neither by thinking nor by doing; we learn to do by thinking about what we are doing.
George D. Stoddard
  #7
Old 12-13-2013, 06:29 PM
BobTPH BobTPH is offline
Default
How about a circuit diagram? Just becuase you said you hooked them up in parallel does not mean you did it correctly.
Bob
  #8
Old 12-13-2013, 06:53 PM
t06afre's Avatar
t06afre t06afre is offline
Default
Quote:
Then using a 1.5 volt battery. The voltage will be safe for the LED. The picture shows a typical voltage current curve for a typical red LED. At 1.5 and up to 1.7 volt the current will be in a safe area. However at about 1.8 the voltage current curve gets very steep. And with a very small increase in voltage you will have currents that might destroy the LED. So the bottom line. With a 1.5 battery the voltage will be safe for say testing since it is the battery chemical properties that decide the voltage. But by using other voltage sources that may drift some. A resistor must be used to protect the LED
  #9
Old 12-13-2013, 07:22 PM
Junior Member
Default
The power source is an power supply from an old printer.
This is new to me so I'm not sure I got the schematic uploaded properly. If not, I'll keep trying.
You're making me wonder now whether the circuit is even viable. Would there be a better way to do this without using a separate power source for each LED?
  #10
Old 12-13-2013, 07:40 PM
wayneh wayneh is online now
Default
I agree you should eliminate - for now - any LED with less than the 510Ω resistor. One or more of them may have failed to a short.
File Type: png Screen Shot 2013-12-13 at 2.38.19 PM.png (43.1 KB, 37 views)
Tags
Related Site Pages
Section Title
Worksheet Basic algebra and graphing for electric circuits
Worksheet Algebraic substitution for electric circuits
Textbook Credits : Contributor List
Worksheet Mutual inductance
Worksheet Magnetic units of measurement
Textbook Parallel-in, parallel-out, universal shift register : Shift Registers
Textbook Serial-in, parallel-out shift register : Shift Registers
Textbook LED sequencer : Digital Integrated Circuits
Textbook (sum) and (product) notation : Karnaugh Mapping
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Science Fair Help - Sensors.... andr3co4 Homework Help 5 02-13-2013 01:20 PM
How to post a project to the collection Dave The Completed Projects Collection 1 01-30-2013 08:15 PM
Science project cajunbrain Homework Help 2 01-15-2013 04:46 PM
DW300 project - one HiFI Audio Amplifier that can run stable on 2 ohm donpetru The Projects Forum 0 12-09-2012 07:37 AM
Science Project - Working Elevator Model - HELP nhnt1 The Projects Forum 8 08-04-2009 12:28 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
