Logic Level Mosfet."Logic level for things like transistors" is a meaningless statement.
Thanks,That is a different question altogether.
Check the spec sheets of the specific logic level MOSFET.
The popular IRLZ44 MOSFET spec sheet states the Gate Threshold Voltage VGS(th)
as 1.0V min and 2.0V max.
Halfway in between would make it 1.5V typical.
That is the input threshold voltage between the gate and source pins.
So to answer your original question, 2V to 5V would work (assuming the source is at 0V potential).
Absolutely NOT. 1.5V is undefined behavior.and of course the 1.5 volt is dead center (and probably a good point to shoot for) ?
Yes, any particular MOSFET you buy can have a threshold anywhere between 1 and 2 volts and still be in spec.Does 'threshold' in this case mean anywhere in between the 1 and 2 v
Sure, as long as you are OK with half your products not working.the 1.5 volt is dead center (and probably a good point to shoot for) ?
In MrChips example, 1.0V and lower is interpreted as "low", 2.0V and higher is interpreted as "high". Anything in between these thresholds can result in undefined interpretations of the signal level, and in worst case scenarios cause some old ICs to oscillate and destroy themselves.
Are you talking about the transistor as a component, or are you talking about TTL logic levels (integrated circuits based on Transistor-Transistor-Logic)?[/QUOTE]
Turning switch on turning switch off.
I understood (or mis understood) him to be saying the mosfet would close given anywhere between 1 to 2 volts to gate.
:shrugs:
I hope I didn't say between .5 and 2.5 I thought you meant between 1 and 2 volts to gate would close the drain/source, and turn on a device that might be hooked up.To confirm what Ernie is saying.
Read the specs carefully. VGS(th) is 1.0V min and 2.0V max.
Let us add to that a 0.5V margin of error.
What this means is that a logic low must be below 0.5V
and a logic high must be above 2.5V.
Hence you do not want to be anywhere between 0.5V and 2.5v for a valid logic signal.
I said it wrong, and N channel is what I'm going to be using.Correct, except for one thing: Current will flow from drain to source, not the other way around (unless you're talking about a p-channel MOSFET?)
You'd be correct.Side question: do they use the term source as a nod to electron flow theory as oppossed to conventional, the actual flow being neg to pos, or source as reference to o potential ?
The FET's three terminals are:
- Source (S), through which the carriers enter the channel. Conventionally, current entering the channel at S is designated by IS.
- Drain (D), through which the carriers leave the channel. Conventionally, current entering the channel at D is designated by ID. Drain-to-source voltage is VDS.
- Gate (G), the terminal that modulates the channel conductivity. By applying voltage to G, one can control ID.
The names of the terminals refer to their functions. The gate terminal may be thought of as controlling the opening and closing of a physical gate. This gate permits electrons to flow through or blocks their passage by creating or eliminating a channel between the source and drain. Electrons flow from the source terminal towards the drain terminal if influenced by an applied voltage.
Source is the source of electrons.I said it wrong, and N channel is what I'm going to be using.
Not in a p-channel MOSFET it isn't.Source is the source of electrons.
I just read that the terms drain and source are a throwback to the water analogy for current flow. The water comes from the source and goes out the drain. I don't know whether what I read is true or not, but it has a certain simple logic to it.Side question: do they use the term source as a nod to electron flow theory as oppossed to conventional, the actual flow being neg to pos, or source as reference to o potential ?
Not in a p-channel MOSFET it isn't.I just read that the terms drain and source are a throwback to the water analogy for current flow. The water comes from the source and goes out the drain. I don't know whether what I read is true or not, but it has a certain simple logic to it.
I don't know if it's relevant to this discussion, but I think it's worth noting that a conducting MOSFET will conduct in either direction. A non-conducting MOSFET will conduct from source to drain via the body diode.Correct, except for one thing: Current will flow from drain to source, not the other way around (unless you're talking about a p-channel MOSFET?)
