All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-01-2008, 11:39 AM
stevy123 stevy123 is offline
Member
Default Variable Capacitor - Trimmer
Hi All
This is probally a very straight foward question for you guys, i have bought a varaible capacitor for a circuit i am building but am a little confused as to how to wire it up. there are 3 pins on it to of which that look the same and one with a red marking on it. Do i connect the 2 that are the same to plus and minus of my battery and then take my trimmed amount off the red terminal or what way?
Many thanks
stephen
  #2
Old 02-01-2008, 12:17 PM
beenthere's Avatar
beenthere beenthere is offline
Default
The capacitor should have a data sheet that explains which pin is which. Your guess about the pins is probably good. With a meter set to ohms, the two pins that read as a short are one side of the cap, and the third, which will check open, will be the variable side.
I am also confused - why a variable capacitor attached to a battery? They are usually used as oscillator trims. Attaching the two pins with continuity to the plus and minus of the battery just shorts it out. Perhaps you have confused variable capacitors with potentiometers which are resistive devices.
Tags
Related Site Pages
Section Title
Worksheet Bipolar junction transistor theory
Worksheet Kirchhoff's Laws
Textbook Radio circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Textbook Practical considerations : Operational Amplifiers
Video Lecture Basic Amplifier Configuration (Part 1) - Op Amps and Op Amp Circuits
Video Lecture Electronic Components Resistors - Basic Components and Technical Notation
Textbook CMOS 555 LONG DURATION FLYBACK LED FLASHER : 555 Timer Circuits
Textbook CMOS 555 LONG DURATION BLUE LED FLASHER : 555 Timer Circuits
Textbook CMOS 555 LONG DURATION MINIMUM PARTS RED LED FLASHER : 555 Timer Circuits
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Square Wave with Variable Voltage dan07 The Projects Forum 33 12-02-2013 01:57 PM
help in programming pic 16f877a by mikro c mastertiger General Electronics Chat 5 08-07-2012 02:51 PM
How to obtain VARIABLE FREQUENCY at output from pic16f72 ? siddharth mittal General Electronics Chat 1 08-10-2009 06:55 AM
Help Variable PWM using A/D PIC18F2431 trr85 Embedded Systems and Microcontrollers 5 06-12-2009 04:36 AM
pointers semiconductor Programmer's Corner 2 01-06-2004 02:28 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
