Boolean tricky problems !!
HMHQ8
Joined Jan 29, 2008
10
Hi Guys,
I have some boolean problems, and if you can solve it ... just do it ;)
1)Write the dual of each Boolean expression. (Insert parentheses so that the result is properly interpreted.)
a) A + B . C
b) A . (B + C’) + (A’(B . C)’
c) A + B + (A + B)’ .C + (A + B + C)’ . D
_______________________________________________
2) Use the axioms and theorems of Boolean algebra to prove the following theorems.
a) (A . B) + (A . B’) = A
b) (A . B) + (A’ . C) + (B . C) = A’ . C
c) AB’ + A’B = (A + B) . (A’ + B’) = (A + B) . (AB)’
d) A + A’ . B . C = A + B . C
3) The following expressions are difficult to read as written. Insert Parentheses to clarify them by identifying the operator hierarchy in each function.
a) A + B’. C + D’ . E
b) A . B + C . D + E + F
c) A . B + C . (D + E . F)’
Let us share the solution :)
chesart1
Joined Jan 23, 2006
269
The dual equation can be obtained by replacing the following:
+ with .
. with +
0 with 1
1 with 0
The principle of duality does not mean that the dual equation must equal the original equation. However, the dual equation must be valid for all values of it's variables.
Example: The dual of:
A + A' = 1
is
A . A' = 0
However the dual of
A + B = 1
is not
A . B = 0
because if A = 1 and B = 1, then A . B is not equal to 0. Therefore A . B = 0 is not a valid equation.
If you need a clear explanation of any other concept, ask.
If you accept a job in engineering, then understanding these concepts may be important. Boolean algebra can be used to design some digital circuits. Sometimes a circuit designed with boolean algebra yields less components than the same circuit designed without boolean algebra. You are making a mistake trying to have someone else do your homework for you.
HMHQ8
Joined Jan 29, 2008
10
Thank you for your support. The problem is that I didnt understand the boolean algebra as I think I should do,, what I mean is I need to know how I can deal with boolean problems, knowing the solution key is the most important thing that I need. However, I did solve these problems but I need to double check the answer.
So, can I show you my answers to correct them or maybe you can tell me how I can do them well.
Thank you again, and really in these days I need some one who can leed me to the correct direction in boolean algebra. :)
