All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-29-2013, 08:08 PM
Sgt.Incontro Sgt.Incontro is offline
Junior Member
Default Solving Transfer Function
I am stuck on this question...
The current source is throwing me off this, and I do not know exactly how to deal with it.
My answer seems very wrong -> V(0)/i(g) = Zr+Zl, so a hand would be greatly appreciated, as I am really stuck.
Thanks.
  #2
Old 10-29-2013, 08:25 PM
Jony130 Jony130 is offline
Default
Try to use a current divider rule
http://en.wikipedia.org/wiki/Current_divider
The Following User Says Thank You to Jony130 For This Useful Post:
anhnha (10-31-2013)
  #3
Old 10-30-2013, 03:50 AM
WBahn WBahn is offline
Default
Quote:
Originally Posted by Sgt.Incontro View Post
Thanks.
Using your answer you have:
V(0) = i(g)(Zr+Zl)
But this would require that ALL of the i(g) goes through the Zr and Zl. What about the portion that goes through Zc?
The Following User Says Thank You to WBahn For This Useful Post:
anhnha (10-31-2013)
  #4
Old 10-30-2013, 07:06 AM
Junior Member
Default
Quote:
V(0) = i(g)(Zr+Zl)
I knew my answer is incorrect, as it does not make any sense.
If it was an ordinary voltage source instead of current source, you would have:
V(o)/V(i)= (Zl+Zr)/( (Zl+Zr) || Zc )
wouldn't you? So how would deal with the current source?
Sorry if I am heading in the wrong direction.
  #5
Old 10-30-2013, 07:33 AM
Default
If it was a voltage source, then the transfer function would be exactly 1.
Think about it.
Going back to the original circuit:
Just analyze the circuit. For instance, sum up the currents going into the top node and set that equal to the currents leaving the top node. You know that the voltage on the top node is Vo. What do you get?
anhnha (10-31-2013)
  #6
Old 10-30-2013, 03:55 PM
Junior Member
Default
Think about it.
You are totally correct about the transfer function being 1 if it was a voltage source. (lol) But is it not possible to do a source transformation?
For the currents:
i(g) = i(c) + i(RL)
and then from there?
  #7
Old 10-30-2013, 04:07 PM
Default
Sure.
Quote:
For the currents:
i(g) = i(c) + i(RL)
I don't know. You haven't indicated what the reference direction for i(c) and i(RL) and I'm not a mind reader.
And then write i(c) and i(RL) in terms of the output voltage.
  #8
Old 10-30-2013, 04:39 PM
Junior Member
Default
I tried a source transformation, am I correct in saying the source transformation would result in a voltage source V(g) followed by a series source resistance of Z(c)||( Z(r) + Z(l) )? (And then the rest of the circuit attached to this?)
I considered both currents facing downwards.
How exactly?
  #9
Old 10-31-2013, 09:17 AM
anhnha anhnha is online now
Default
Maybe, I can help a bit.
I think it is right. However, what is the purpose for this?
Please see the picture:
1.What is relation between ig, I1, I2? In other words,write the equation that relates ig, I1, I2 through Kirchhoff's Current Law for node A.
2.Express I1 in terms of Vo?
3 Express I2 in terms of Vo?
Substitute I1, I2 expressions you got in #1 and #2 into #1.
Now can you derive Vo/ig?
The Following User Says Thank You to anhnha For This Useful Post:
Sgt.Incontro (10-31-2013)
  #10
Old 10-31-2013, 03:54 PM
Default
How exactly?
I don't know what happen to the response I thought I had posted. Oh well.
1) What is the voltage across the capacitor?
2) What is the impedance of the capacitor?
3) What is the current through the capactor?
4) What is the voltage across the series combination of R & L?
5) What is the impedance of the series combination of R & L?
6) What is the current through the series combination of R & L?
Tags
Related Site Pages
Section Title
Textbook Special transformers and applications : Transformers
Textbook Series-parallel R, L, and C : Reactance And Impedance -- R, L, And C
Textbook Parallel R, L, and C : Reactance And Impedance -- R, L, And C
Textbook Circuit components : Using The spice Circuit Simulation Program
Textbook Node voltage method : Dc Network Analysis
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help needed with transfer function for two stage rc ladder network! AaronR84 Homework Help 4 10-21-2013 07:40 PM
BJT Op-Amp and Feedback Transfer Function tquiva Homework Help 0 11-14-2012 05:35 AM
Transfer Function jay0456 Homework Help 1 05-21-2011 05:01 PM
Finding Poles and Zeros Location from Transfer Function prietess The Projects Forum 3 04-06-2011 07:00 AM
Transfer Function Problem cheyenne Homework Help 1 03-28-2008 08:28 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
