All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-14-2013, 10:20 PM
jvcmarine jvcmarine is offline
Default Toggle Switch Terminology
I know I'm getting old when I can't recall basic stuff, or maybe I'm just a dumb ass!
Looking at toggle switches.
DPDT. I assume this switch would have six contacts and have three detente positions, down, middle up, or left, middle right. LOL.
Below are the descriptions from the Carling data sheet.
I have two questions:
1: What is the difference between Off and None.
2: What do the parenthesis mean.
3:Why don't they provide a switch schematic.
ok I know that's three.
ON-NONE-OFF
(ON)-NONE-OFF
ON-NONE-(OFF)
ON-NONE-ON
ON-NONE-(ON)
ON-OFF-ON
ON-OFF-(ON)
(ON-OFF-(ON)
  #2
Old 10-14-2013, 10:27 PM
#12's Avatar
#12 #12 is offline
Default
The parenthesis means momentary.
Who knows what, "none" means?
__________________
It's only my opinion, and sometimes I'm wrong.
(I learn something almost every day on this site.)
  #3
Old 10-14-2013, 10:36 PM
MaxHeadRoom's Avatar
MaxHeadRoom MaxHeadRoom is online now
Default
Quote:
DPDT = 4 contacts, and if not specified 'Center Off' then only two positions.
ON-NONE-OFF
(ON)-NONE-OFF
ON-NONE-(OFF)
ON-NONE-ON
ON-NONE-(ON)
ON-OFF-ON
ON-OFF-(ON)
(ON-OFF-(ON)
Never seen most of those descriptions, I am assuming the NONE means centre off?
Max.
__________________
"Make everthing as simple as possible, but not simpler"
Albert Einstein.
  #4
Old 10-14-2013, 10:37 PM
WBahn WBahn is offline
Default
It means there is no center position at all, as opposed to OFF, which means that there is a stable center position in which neither of the circuits is connected.
So a typical SPDT switch used for a stairwell light would be ON-None-ON.
  #5
Old 10-14-2013, 10:43 PM
Default
That seems a bit redundant specifying NONE for a position that does not exist?
I am used to SPDT - Centre Off, or ON-OFF-ON for a three position switch.
If simply SPDT then this would automatically be assumed as a two position switch?
Max.
__________________
Albert Einstein.
  #6
Old 10-14-2013, 10:44 PM
Default
If those are the options listed specifically for a DPDT switch, then I don't have any idea what something like ON-None-OFF would mean. It's a double throw switch, which means there needs to be two "ON" states in there somewhere. So the first three listings don't make sense to me.
Other possibilities, though probably custom order, would be something like
ON-ON-(OFF)
meaning that the one side and the center positions connect the common pole to the two circuits and that the other side is a momentary that disconnects both circuit but that returns to the center ON position when released.
  #7
Old 10-14-2013, 10:50 PM
MrChips's Avatar
MrChips MrChips is offline
Super Moderator
Default
SPST OFF-None-ON
SPDT ON-None-ON
SPDT-Center Off ON-OFF-ON
Any (ON) means it is momentary, i.e. spring return to previous position when released.
For example,
(ON)-OFF-(ON) is a SPDT that returns to centre OFF when pushed to either side and released.
__________________
Most computer problems can be attributed to a simple problem - a loosewire behind the keyboard.
The Following User Says Thank You to MrChips For This Useful Post:
Sensacell (10-15-2013)
  #8
Old 10-14-2013, 10:58 PM
Default
Using the None simply makes it so that data sheet tables can be made in a consistent way. For instance:
Option CodeLeftCenterRight
A3ONOFFON
B7(ON)OFFON
B9ONNONEON
C1(ON)ON(OFF)
It also allows unambiguous encoding in a parts database.
  #9
Old 10-14-2013, 11:01 PM
Default
Then what would a maintained SPDT centre off be, in post #5 the ON-OFF-ON would be maintained, if not it would be labeled Momentary. ?
It seems to me those descriptions by the OP is confusing and using descriptions that vary from the industry norm, which usually are self explanatory?
Max.
__________________
Albert Einstein.
  #10
Old 10-14-2013, 11:07 PM
Default
Quote:
Originally Posted by MrChips View Post
For example,
How do you know this is a single pole switch and not a double pole or even an 8-throw switch?
This encoding tells you how many throws there are, but nothing about how many poles.
It also doesn't given any hint about make-before-break conditions designed into the switch. I've seen a simple encoding that included that but can't recall for sure exactly what it was. I believe it just an added a '+' or '-' between adjacent positions with a '+' meaning make-before-break and a '-' meaning break-before-make. Either could be used if the adjacent is an OFF but I think the '-' was used as a default.
So something like
(ON)+ON-OFF
meant that the two adjacent ON positions, the extreme one of which was momentary, and that a make-before-break action joined them.
Using this encoding, a two position (no center position) SPDT switch with make-before-break would appear as
ON+NONE+ON
while the same switch with break-before-make would appear as
ON-NONE-ON
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Little wiring project for my boat Arkman The Projects Forum 5 05-18-2012 08:16 PM
Momentary switch to latched on/off toggle andyman The Projects Forum 2 01-19-2009 08:51 PM
voltage tests and thermostats ac circuits bonkers General Electronics Chat 4 12-14-2008 12:41 PM
Help wiring an illuminated automotive toggle switch - please. bajafx4 The Projects Forum 2 11-26-2008 05:06 PM
Chef needs momentary switch help.auto related chefandy1969 The Projects Forum 5 04-01-2007 01:50 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
