Well, considering this is Homework Help you should start h\by stating what you need help on - note the difference between helping you and doing it for you (which we won't be doing).I want to make 8:1 mux using two 4:1 mux. practically. I want to make it using both, gates and multiplexer i.c. Please help me out soon.
Is there a question in this? What is it that you would like help on? And how soon?I want to make 8:1 mux using two 4:1 mux. practically. I want to make it using both, gates and multiplexer i.c. Please help me out soon.
What do you consider to qualify as "practically"? Most people wouldn't consider making an 8:1 MUX using gates to be a very practical thing to do.
Which 4:1 MUX do you have in mind?
No, the '153 doesn't consist of independent 4:1 MUXes, the two MUXes share the same select bits.Can we make 8:1 using 74LS153???
I don't hav much knowledge about MUX IC's.
hi,I want to make 8:1 mux using two 4:1 mux. practically. I want to make it using both, gates and multiplexer i.c. Please help me out soon.
The main thing I asked for was the relationship between the inputs and outputs. After all, I can make lots of chips with six inputs and one output that are NOT a 4:1 MUX. But I'll just assume that you understand these relationships.Yeah, i know the basics... a 4:1 MUX consist of 4 inputs, 2 selection channel and 1 o/p.
whereas a 8:1 MUX consist of * i/p, 3 selection channel and 1 o/p... right??
by Jake Hertz
by Aaron Carman
by Aaron Carman
