Hello
first of all , thks for all the help, this is a very good forum.
I have build my switching power circuit, so I will post it here, and I accept any sugestions, if I have any mistakes please report.
If this is very bad, please try to understand that it's my first switching design
Here is the BOM details:
qtd - label - details
2 - J1 + j2 - connector 2.5mm metric 5mm
1 - R0 - resistor zener D1
1 - D1 - zener for MOSFET
1 - Q1 - Mosfet P-channel FQPF47P06
3 - C3 , C2 , C1 - capacitor elect CIN 15uF 50V
1 - C4 - capacitor CINx .47uF 50V
1 - D2 - diode schotky SB560(sugested is 80SQ045, but i has 2mA of leak current
1 - R1 - resistor 1kOhm 1/4w
1 - R2 - pot 10k (5 volts 3.132ohm) package PRE-SQ2
1 - U1 - IC DC LM2679-ADJ
1 - R3 - resistor 7425ohm
1 - C6 - capacitor boost 0,01uF
1 - C5 - capacitor soft start 3.3nF
1 - L1 - indutor toroidal 22uh 5.22A
1 - C7 - capacitor COUT ceram 0.47uf
2 - C8, c9 - capacitor COUT elec 180uF 50V
1 - R4 - resistor led 1Kohm
1 - D3 - diode LED, 10mA
Designed for use with input voltage of regulated DC 12volts or regulated Dc of 24volts
Output voltage, fine adjust between 5 and 5.5volts( best case scenario of 2.5amps, worst case scenario of 3.2amps)
