All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-18-2008, 11:11 AM
uzair's Avatar
uzair uzair is offline
Unhappy Why Ammeter is connected in series?
We connect an ammeter in series, but what is the reason for it?
A good link can also help!
  #2
Old 01-18-2008, 11:13 AM
hgmjr's Avatar
hgmjr hgmjr is offline
Super Moderator
Default
Here is the info on ammeters in the AAC ebook.
hgmjr
  #3
Old 01-18-2008, 11:31 AM
uzair's Avatar
Default
The ammeter is not connected in parallel because it will draw large current and disturb the circuit, right?
  #4
Old 01-18-2008, 11:36 AM
beenthere's Avatar
beenthere beenthere is offline
Default
It is in series because current flows in parallel branches of a circuit. The ammeter has to be a series element in order for all the current to go through it.
  #5
hgmjr's Avatar
Super Moderator
Default
Quote:
Yes, that is correct.
An ammeter by its nature has a very low input resistance. That is why if it is connected in parallel with a circuit element such as a resistor or a capacitor, it is the same as placing a very low resistor in parallel with the component or components across which is paralleled.
hgmjr
  #6
Old 01-18-2008, 12:19 PM
uzair's Avatar
Default
Ok thanks now i feel clearer about it
  #7
Old 01-20-2008, 02:14 PM
rwmoekoe rwmoekoe is offline
Default
i thought this might get it clearer too.
when we want to measure the current flow in a wire, the current should pass our ammeter, that is in series, to let it do the task. if we put it in parallel with the circuit we wanna measure, then it won't be doing the job of measuring the current flow in th circuit, instead it is generating a new current loop parallel to the first circuit.
  #8
Old 01-21-2008, 05:03 PM
cumesoftware's Avatar
cumesoftware cumesoftware is offline
Default
In practice, you will cause a short circuit and you may damage the ammeter. So use your ammeter always in series with the load for which you want to measure the current. The ammeter has such a small resistance that will not cause any significant voltage drop. So the load won't be disturbed.
__________________
I love the smell of toasted transistors in the morning.
Tags
Related Site Pages
Section Title
Worksheet AC motor control circuits
Worksheet DC motor theory
Worksheet Ammeter design
Worksheet Basic ammeter use
Textbook 4-wire resistance measurement : Dc Circuits
Textbook Make your own multimeter : Dc Circuits
Textbook Current divider : Dc Circuits
Textbook Ammeter usage : Basic Concepts And Test Equipment
Textbook Ammeter impact on measured circuit : Dc Metering Circuits
Textbook Ammeter design : Dc Metering Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Detect which sensor connected and general sensors ikosen The Projects Forum 10 07-18-2012 01:15 AM
RA4/TOCKI in 16F84A tracecom Embedded Systems and Microcontrollers 2 05-21-2012 04:11 AM
transistor connected to actuator J.Green The Projects Forum 17 06-06-2011 03:23 PM
Delta Connected and Star Connected Load Questions haseeb112 Homework Help 4 12-08-2009 03:12 PM
Fourier series coefficients whoozit Homework Help 2 02-29-2008 09:17 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
