Dimming white leds
boatsman
Joined Jan 17, 2008
187
I have an array of 12 white leds powered by three AAA batteries. The light they emit is bright. I want to be able to adjust the intensity of the array from off to full brightness. If I just use a potentiometer the leds are either on or off. How can I make a simple dimmer?
wayneh
Joined Sep 9, 2010
18,182
There are several simpler circuits that folks use, but PWM as recommended by Bertus is the best, especially if you want a nice full range of control.
The second best approach is probably the LM317 based circuits.
Last choice is what you already tried. It could be made to work, but a potentiometer that can handle the power will be more expensive.
LDC3
Joined Apr 27, 2013
924
Did you notice that the power is coming from 3 AAA cells? The voltage is about 4.5 V and probably has a current less than 100 mA. A 1/2 watt potentiometer is probably cheaper than building any circuit.
DickCappels
Joined Aug 21, 2008
10,661
It sounds like your basic problem is that your pot (actually used as a rheostat in this case) has too high of a resistance. Try a lower resistance part, such as 10k, 5k, or 1k and you will not see the on/off effect.
THE_RB
Joined Feb 11, 2008
5,438
The PWM solution will be a lot more energy efficient (ie give longer battery life) than just using a resistor (or large pot).
It will also give a better light quality when dimmed.
That makes it a better option, even though it takes more effort to build.
