All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-14-2008, 09:36 PM
conehed conehed is offline
Junior Member
Smile Maximum demand indicator
good evening again-
could you give guidance and advice on the following qusestion please.
"Maximum demand indicators utilise an auxiliary pointer driven by a main pointer. Explain the use of this auxiliary pointer, the problems it may cause and how these problems can be overcome."
Thankyou
  #2
Old 01-14-2008, 09:41 PM
Papabravo's Avatar
Papabravo Papabravo is offline
Default
Gee I dunno. Are we talking about the auxiliary pointer creating enough drag on the main pointer to prevent it from producing an accuarate reading? I've never used one and can't imagine why I would -- It sounds very 1950's
Most digital meters have a maximum hold function built in.
I can see you are a man of your word. Always a good thing.
__________________
We never have time to do it right,
But we always have time to do it over.
  #3
Old 01-14-2008, 10:38 PM
beenthere's Avatar
beenthere beenthere is offline
Default
That must be like a magazine thermometer that has an indicator that will show the highest temperature reached during the recording session. Can't really see why it would cause a problem, unless it responded to a glitch and indicated a one-time event as significant. I would think that anything critical would have a recording device that would make a permanent record, and not just a maximum reading.
  #4
Old 01-15-2008, 02:22 PM
Junior Member
Default
This question does not make any sense really! we is all confused.com- however, i wonder if the following would make sense as an answer???? Your veiws please.
1. Maximum Demand Indicators. A composite part of a maximum demand indicator is an auxiliary needle which is driven by the average demand needle and locked in place with a frictional device. The function of the secondary needle (usually red) is to mark the maximum power demand/usage since the needle was last reset. The following problems are inherent to this type of device:
a. Misleading Readings. The maximum demand indicator marks the maximum value recorded on the meter, even if this is an abnormal level due to an unexpected surge in demand. This can be avoided if the maximum demand is regularly recorded and the needle reset, as abnormal readings would be highlighted.
b. Tampering. As this device is reset manually, it can be tampered with giving misleading results. The device should have some kind of security or locking device attached to it.
Thankyou
Tags
Related Site Pages
Section Title
Textbook Synchronous Motors : Ac Motors
Textbook Measurements of AC magnitude : Basic Ac Theory
Textbook What is a meter? : Dc Metering Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Maximum Power Transfer mlkcampion General Electronics Chat 3 07-01-2007 02:23 PM
Maximum possible value of remainder atferrari Math 2 04-18-2007 08:00 PM
maximum power transfer sathya Radio and Communications 0 06-03-2004 04:13 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
