All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-13-2013, 09:36 PM
AD633 AD633 is offline
Member
Default Circuit with BJT and JFET transistors
For the following circuit determine the voltages VG,VC and VD
VG
For determing Vc i need to know the value of the current Ic of the BJT.
For determing Ic do i need to determine Id first?
For determing Ib (not sure if this equation is correct)
I need to know what the value of the current Id and Vgs in order to determine the value of VD right?
Can i determine VD from this equation:
Suposing that the BJT works in the ative region therefore IE is equal to Id
How can i determine VD and VDS from what i already know..
  #2
Old 07-14-2013, 01:44 AM
t_n_k t_n_k is offline
Default
Firstly, check your incorrect equation for VG from which you (luckily) obtain the right value ....
Next you need to set up some equations to solve for the FET drain current.
The base equation is
You already know VG and VS is found from
So
You solve equations 1 & 2 to find FET drain current. The rest will follow from this.
  #3
Old 07-14-2013, 05:22 PM
Member
Default
So
So i have to do a system of equations with:
I have found and
Now suposing that the BJT is in the ative region.Id=Ie ,and Ie is aprox equal to Ic
Therefore
For determing Vd
The problem is that i don't know neither vd or vds.Do i need to find ib first for determing Vd?
  #4
Old 07-16-2013, 03:06 PM
Member
Default
Quote:
I have found and
Therefore
For determing Vd
  #5
Old 07-16-2013, 04:05 PM
Jony130 Jony130 is online now
Default
OK, but how can Id current be larger than Idss and and also Vp and Vgs?
So you need solve this equation again.
  #6
Old 07-16-2013, 11:36 PM
Default
@ AD633
.Remember that quadratic equations usually have two roots - not one. You chose the wrong root. The value must make sense physically as well as mathematically.
  #7
Old 07-17-2013, 01:48 PM
Member
Default
@ AD633
I have found and
Therefore
For determing Vd
  #8
Old 07-17-2013, 02:18 PM
Default
Well the correct answer is
Id = 4.23621mA and Vgs = -0.958448V
And yes, you need to know Ib first to find Vd = Ve voltage.
  #9
Old 07-17-2013, 02:44 PM
Member
Default
For finding Ib do i need to use a system of equations?Something like:
Or assuming that the BJT is in the ative region and that Ie is approx equal to Ic
  #10
Old 07-17-2013, 03:07 PM
Default
Yes, first assume that BJT is in active region and find Ib current.
Then you need to check if your assumption about BJT active region was right.
What?? Ic = ??
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
